compression 9 to 1 VS. 11 to 1
Old May 4th, 2007, 12:16 AM   #1
ryanw's Avatar
1991 Ford Mustang GT
ryanw has a spectacular aura aboutryanw has a spectacular aura about
My question is , if you have 3 high proformace engines all with the same parts and the only difference is the compression ratio, for example lets say the 9 to 1 compression engine has 225 hp, what would the horse power be at 10 to 1 and 11 to 1? is there a mathethmatical formula to this?
Old May 4th, 2007, 12:59 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It depends....
There is no formula that I know of. I've heard engine builders say 1 compression point is worth 20-25 horsepower but it really depends on the rest of the combination.
Old March 30th, 2010, 11:06 PM   #3
mgrah87 is on a distinguished road
good question im in the middle of a 351 stroked to a 408 running 11:1 with 61cc combustion chambers.
Old November 13th, 2010, 03:10 AM   #4
ryanw's Avatar
Any more thoughts ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 13th, 2010, 09:24 AM   #5
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Waiting 3 years for answers is some serious patience. I woulda bumped it a few more times, lol.
A whole bunch of crap that makes the car go fast
Old November 13th, 2010, 10:06 AM   #6
ryanw's Avatar
Ya when i posted this i never saw the answer. I forgot all about it. im still figureing out this site when i ran across it so i thought id bump it and see if i cant get it rolling. if it turns out to be a topic that know care about this time ill let it go. ha ha. 1slo5.0 gave a good answer and maybe its not going to get much better that
255 fuel pump,
3:27 gears
Old November 13th, 2010, 10:18 AM   #7
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
There is no good answer, because it takes a lot different cam profile to run a 9:1 engine, than it does an 11:1 engine. So if you build the first engine at 9:1, and you bump that engine to 11:1, your combo will be wrong, therefore you will not get the most out of your newfound compression.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Threads Similar to: compression 9 to 1 VS. 11 to 1
Compression mustangmanic 99-04 12 October 10th, 2007 11:01 PM
compression? matfernan1 99-04 5 August 31st, 2007 12:42 AM
Compression Clockman 94-95 3 May 4th, 2007 04:16 PM
compression greenstallion 99-04 4 March 8th, 2007 07:40 PM
compression greenstallion General Tech 2 March 6th, 2007 12:24 PM
