90 Mustang GT AC/ vac line question
LinkBack (1) Thread Tools
Old April 24th, 2011, 09:13 PM   1 links from elsewhere to this Post. Click to view. #1
polmonari is on a distinguished road
Hey Guys,
I'm new to the site and I'm starting off with a question of course. Air does not come out except for my defrost and seems like a hole @ the box on the passenger side. I went under the hood and found 2 lines coming from the tree to the pass side labeled AC. 1 is going into the fender and appears to be hooked into the temp controls. The other one is cut off, just wondering where that is supposed to go and will that fix my problem.
Thanks for your help
Old April 24th, 2011, 09:41 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
I think the other cut line runs along the fire wall to the passenger side, i think its that one thay makes your system run in defrost all the time
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 24th, 2011, 09:54 PM   #3
I think you may have misunderstood me. There is one line coming off the "t". It runs the firewall and then when it gets to the passenger side it splits into 2 lines. 1 goes into the fender well and the other one is cut very short. Wondering where that one is to go?
Old April 24th, 2011, 10:30 PM   #4
ryanw's Avatar
Okay.....The one that's cut goes into the fire wall right where your A/C accumulator line are.(The black canister looking thing), If you see that black square rubber pad on the fire wall look at the top right hand corner and you will see a small round hole....that's were the vacuum line goes in to the interior....I hope that helps
255 fuel pump,
3:27 gears
Old April 24th, 2011, 10:37 PM   #5
Ok great. Thank you. Do you know where it goes from there?
Old April 24th, 2011, 10:42 PM   #6
ryanw's Avatar
No...sorry
255 fuel pump,
3:27 gears
Old April 24th, 2011, 11:13 PM   #7
gaducker's Avatar
gaducker is on a distinguished road
It goes inside to work your vac motors on the blend doors and it runs to the control panel for heat and AC,
Old April 24th, 2011, 11:17 PM   #8
I see a white hose going to the vac canister right behind the glove box. But cant figure out what im missing. I think I really need to see a diagram of the system. Where would I find that?
Old April 28th, 2011, 10:40 PM   #9
Ok, so I am trying to figure out where this vac line is suppose to connect. There are 2 lines under the hood that are labeled AC. One is routed into the fender and the other goes into the firewall.
Once it goes into the firewall where is it suppose to go? Where does it connect to?
Old April 28th, 2011, 10:44 PM   #10
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I believe the vac canister is on that side. It's a round ball that holds/stores vacuum.
Old April 30th, 2011, 09:52 PM   #11
thanks guys,
just found where it went, and what do ya know. I have cold air thru all vents now!
Old April 30th, 2011, 11:13 PM   #12
ryanw's Avatar
Originally Posted by polmonari View Post
thanks guys,
Right on, I'm glad we could help.
255 fuel pump,
3:27 gears
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/215392-90-mustang-gt-ac-vac-line-question.html
Thread 90 Mustang GT AC/ vac line question | Forums at Modded Mustangs | BoardReader This thread Refback July 10th, 2011 08:36 PM
Threads Similar to: 90 Mustang GT AC/ vac line question
line lock question BlkGt03 99-04 48 February 16th, 2011 09:59 AM
brake line question 1999cobra92 2005 - 2010 4 January 31st, 2011 10:46 AM
Brake line question red01 96-98 1 January 30th, 2011 06:32 PM
Old gas, fuel line question DegralDan 99-04 3 September 28th, 2010 10:19 PM
Fuel Line question PolishSasquatch 5.0 Mustangs 6 May 8th, 2009 03:35 PM
