Started digging around in the 95 GT
Old April 24th, 2011, 10:43 PM   #1
twiprod001's Avatar
1995 Mustang 5.0 GT
twiprod001 is on a distinguished road
Well , I got this 1995 GT on a trade deal. The car is in very good condition in my opinion. There has been alot of work done to the car by the PO. What was done ??
I don' know. So I started digging around this weekend and here's what I found out so far between visable work and receipts that came with the car..
(over 4 grand in receipts)
5.0 pushrod V8 215 hp from the factory.
New purchase price was $14530.00 (GT Coupe)
Color: Canary Yellow (3,497 made)
Total Production 137,722
1- All the pollution controls have been removed. (air pump / cats /ect..)
2- BBK shorty headers
3- 2.5 " H-pipe
4- Flowmasters
5- New Radiator
6- New Borg Warner T5 trans
7- New U-Joints
8- C&L Performance Cold Air Intake
9- New idle control motor
10- New throttle body
11- A/C is not working( looks like the PO was going to have it removed)
12- Heater hoses are capped off in the engine bay
13- New air pump replacement pully
14- New serpentine belt
15-New water pump
16-New fuel pump
17- New brakes
18- New Exedy Mach 500 stage 2 clutch
Now I have to find out if any work was done to the engine. I was told the engine was rebuilt and why would you rebuild an engine and not do some upgrades?
How much additional HP would the above upgrades produce?
As I find more stuff I'll post it.
Bernie
It is what it is....
Old April 24th, 2011, 10:50 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
If the heater hoses are capped, it makes me wonder if the heater core is leaking. Cuz i have no clue why any one would disconect a heater, Defrost is a must regrdless of where you live.
When the fuel pump was replaced was it upraded to a bigger one?
When the throttle body was replaced was it upgraded to a bigger one ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 24th, 2011, 11:09 PM   #3
twiprod001's Avatar
1995 Mustang 5.0 GT
I'm still digging but I will check to see if those were upgraded. I did look to see if there was any rust or rotted carpet in the heater core area and it's all in great shape. I have no idea why the hoses are capped off. But there's one way to find out.. I'll post what I find.
Old April 24th, 2011, 11:25 PM   #4
ryanw's Avatar
keep us updated
255 fuel pump,
3:27 gears
Threads Similar to: Started digging around in the 95 GT
And now, Hot Everyday Girls Digging. TheUNZippee! The Clubhouse 38 August 8th, 2010 03:07 PM
You started it! JakeM The Clubhouse 8 July 11th, 2010 11:08 AM
So i started jasons_98gt 96-98 10 April 2nd, 2010 03:35 PM
got it started...again viperlocc 5.0 Mustangs 2 March 29th, 2009 10:17 PM
Just getting started jwyche New Members Introductions 28 January 11th, 2008 06:17 PM
