Exhaust port matching
Old May 4th, 2007, 01:48 AM   #1
Zak
Zak is on a distinguished road
Most of us know what should be done when it comes to gasket-matching the intake ports for both the manifold & head.
But when it comes to the exhaust side, it's confusing.
I have Windsor Sr Lite heads, Fel-Pro 1415 (1.250"x1.480") and BBK 1-5/8" shorties. The opening dimensions are different with all the 3 above:
The gasket openings are too large for the head exhaust ports.
The headers on the other hand have different dimensions: the header flange openings, then reduced through the welded joints to the header pipe bore!
First of all do I need to port the exhaust side for N/A? Should I stick to the pipe bore dimensions or port the heads to match the gaskets?
Thanks!!!
Threads Similar to: Exhaust port matching
Paint Matching OcOnnor220 99-04 3 August 9th, 2007 02:19 PM
Single Port vs. Split Port One Bad Sixxx V6 Mustangs 24 June 2nd, 2007 10:26 AM
port matching pi manifold slow98gt 96-98 3 May 11th, 2007 08:27 PM
single port to split port 94pacecarSVT V6 Mustangs 5 February 2nd, 2007 12:25 AM
Matching Amp to Sub Xeremeh Audio/Video 6 December 8th, 2006 12:20 AM
