Vacuum Lines Question - Page 2
Old April 25th, 2011, 07:40 PM   #21
ryanw's Avatar
1991 Ford Mustang GT
starting from left to right
#1 intake vacuum
#2 EGR vacuum
#3 smog pump valve
#4 other smog pump valve ( the one that's closes to the smog pump )
but as fogged pointed out you may not need this any more so this info maybe worthless to you, but i hope it helped.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 25th, 2011, 07:47 PM   #22
Those lines that are cut go to the pas side strut tower where the TAD and TAB solenoids are.. these are part of the Smog system and since you have an EGR block off plate (that's the plate bolted to the back of the spacer that sits between the throttle body and upper intake) im willing to bet the smog pump is gone to so unbolt the TAD/TAB and remove along with those vacuum lines.
There is a vacuum ball and vacuum canister bolted on the inside of that pas fender out of sight that each get a vac line. I don't remember which one but one of them need a vac line in order for your vents to work with your heat. If it's not connected then heat won't come from your vents it'll only come out of the top of the dash and shit but the other which ever one it is can get tossed.
here's how i routed mine don't know if it'll help hyou at all but it has all the lines needed to run except the one line to the pas fender to the vac canister so the vents will work.. everything else was capped off and or removed. Oh and that "EVR" is to the EGR solenoid which is bolted on the strut tower next to the TAD/TAB solenoids.. I kept mine so disregard that one for your case.
Old April 25th, 2011, 08:16 PM   #23
jeremyalms's Avatar
1991 LX
jeremyalms is on a distinguished road
Thanks guys... I went ahead and removed all 3 solenoids on the tower, and my heat still works and still switched from vent to floor to defrost... On to the next dilemma!
Threads Similar to: Vacuum Lines Question
NEED HELP-Vacuum Lines 67svtstang 99-04 7 July 27th, 2010 07:38 PM
Vacuum lines sniperd 5.0 Mustangs 11 May 26th, 2009 02:54 PM
vacuum lines ??? worlz08 5.0 Mustangs 1 October 7th, 2008 11:07 PM
vacuum lines terribleonexx88 5.0 Mustangs 2 October 19th, 2006 02:18 PM
vacuum lines 88stang 5.0 Mustangs 11 April 4th, 2006 04:16 PM
