having a transmission problem
Old April 27th, 2011, 04:26 PM   #1
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
i got an aod in my 89, it has been shifting fine manually at the track but last saturday when i shifted into 2nd it went into 2nd then straight into 3rd, the kickdown is tight and it doesn't slip any, any ideas from the great 5.0 guys in here?
www.hsvracing.com
Old April 28th, 2011, 02:24 PM   #2
dblzroracin's Avatar
92 Mustang GT vert
dblzroracin is an unknown quantity at this point
Send a message via AIM to dblzroracin Send a message via Yahoo to dblzroracin
What gears are you running?
www.bbandtracing.com
Old April 29th, 2011, 10:30 AM   #3
1990 hatchback lx
4.10's but it just started it, used to shift fine
www.hsvracing.com
Old May 25th, 2011, 03:22 PM   #4
1990 hatchback lx
no one here has ever had this problem?
www.hsvracing.com
Old May 25th, 2011, 03:52 PM   #5
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
If the aod is all stock, thats the way they normally shift when you shift them manually. Normally you will have to do whats called a shuttle shift, which is manually shift into second, then pull it back into first, it should stay in 2nd, then when you shift into 2nd again it will go into 3rd.
Your best bet would be a Trans Go AOD HP shift it which replaces the manual valve so you can hold 1,2,3 to any rpm, plus it comes with a high rpm govener kit that allows you to leave it in D and it will shift itself between 5500-6000 depending on the throttle cable setting.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old May 26th, 2011, 10:25 AM   #6
92 Mustang GT vert
I have seen AODs shift alot quicker even with 3.73 gears are installed. Like stated above pull the shifter back to 1st after shifting into 2nd to hold 2nd gear as long as you want.
Old May 26th, 2011, 04:28 PM   #7
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Manually shifting on a stock aod is gonna kill it pretty quick.Sound like your gonna need to fix it soon anyway..Get a stall and a manual valvebody.I getting mine rebuilt next week.My old one didnt last long with me beating on it.
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old May 27th, 2011, 05:28 PM   #8
1990 hatchback lx
it has the trans go kit and a ptc stall converter, it use 2 hold 1st, still holds 1st, goes into 2nd then into 3rd now, i can't figure it out, i hadn,t changed anything, i even clamped off the cable so it'll have constant pressure but it still shifts early, it's a drag car not a street car, 1/8th mile at a time
www.hsvracing.com
Threads Similar to: having a transmission problem
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
Transmission Problem HTK241 94-95 7 March 26th, 2008 06:27 PM
Transmission Problem? ricer_slayer 5.0 Mustangs 12 February 26th, 2007 07:32 PM
Transmission Problem 623MUSTANG 99-04 4 August 10th, 2006 03:29 PM
Transmission Problem 173speed 5.0 Mustangs 6 April 13th, 2006 10:57 PM
