What do you think of my bearings - Page 2
Old April 28th, 2011, 11:58 AM   #21
nxcoupe is on a distinguished road
How many miles on that engine? Looks like it was run low on oil at some point or was put together with too tight of clearances.
90 GT 393 5 spd, 467 rwhp 480 rwtq
92 coupe, R/S 308 5 spd
93 coupe, 2.3 5 spd
Old April 28th, 2011, 12:43 PM   #22
GMcanblowmyFORD's Avatar
1993 stang GT
NA
GMcanblowmyFORD is on a distinguished road
well i picked this car up from ohio 2 years ago and the guy that owned it 5 lugged it and built the rear with 373's but never changed the plastic gears to keep the speedo right so im guessing 110,000 to 120,000 miles..the motor was all stock when i got it
ill still smoke honda's with no engine in my stang!
You dig the trench I lay the pipe!
Old April 28th, 2011, 12:49 PM   #23
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
wow those are fucked
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old April 28th, 2011, 05:39 PM   #24
fogged306's Avatar
89 GT
Going 28oz will need a new crank, balancer, and flywheel. Believe me, if you're going to spend the money, get a 347. If you're going 306, you're already buying new pistons, and if you go 28oz, you're already getting a crank. Spend the extra few hundred and get the rods and clearance the block. Make a lot more power with not a whole lot more money spent. Also be sure to stud the mains and line hone it...... And then buy my super Vic and spin the shit out of that motor.
Old April 28th, 2011, 07:30 PM   #25
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
Those aren't too bad... Flip em over and use the good side!
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old April 28th, 2011, 09:03 PM   #26
1993 stang GT
NA
CHP Street Fighter Short Block - Ford 347 Reverse Dome -14.2cc -- Best way to go?
Old April 28th, 2011, 09:15 PM   #27
fogged306's Avatar
89 GT
What heads do you have? CHP sells decent kits, and I know probe makes nice pistons and rods, but I don't know shit about their cranks. I know I saw mark, the owner of probe, mention on another forum that he used to work somewhere and made cranks ... And hated doing it. So I would check to see if they're made in house, or imported. If theyre made in house (or even cast overseas and machined in house), i would probably expect them to be good quality. Also see if you can get a bobweight for that kit.
Having said that, you can get a smaller dish, or a flat top piston and get some more compression out if that too.
Old April 28th, 2011, 10:26 PM   #28
FastStang91Lx's Avatar
1991 Mustang LX 5.0
That's what I do with my boxers...
Old April 28th, 2011, 10:29 PM   #29
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I have to do that with my pants, because I don't wear boxers
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old April 28th, 2011, 10:37 PM   #30
1991 Mustang LX 5.0
Commando....baby!
Old April 28th, 2011, 10:49 PM   #31
fogged306's Avatar
89 GT
Just read a very relevant thread on this and saw woody mention that the 5.315 rods need to have the counterweights on the crank lathed down in a lot of cases because they bring the pistons down into them. Also saw a guy mentioning a kit with a probe crank and woody (guy who owns fordstrokers) told him to specify a scat crank, so apparently he's dealt with a probe crank before and wasn't impressed. Take that advice for what it's worth because it's secondhand, but woody is a pretty good source.
Old April 29th, 2011, 08:11 AM   #32
1993 stang GT
NA
ill just look for a short block with a scat assembly, i already have to sell my 4wheeler for this build so what a couple more hundred...dont have heads yet but im thinking save my money and get some trickflow heads
Threads Similar to: What do you think of my bearings
Rod bearings/Oil Pan tnknepp Classic Mustangs 4 August 24th, 2009 01:21 PM
rod bearings Boostang 99-04 1 August 8th, 2009 08:57 PM
bearings?? badf150boy123 99-04 1 April 1st, 2008 10:02 PM
bearings? mpboy 99-04 0 February 4th, 2008 10:40 PM
3.8 Rod Bearings T_O_A_D V6 Mustangs 4 August 17th, 2006 11:25 PM
