Discussing Any Horsepower Gains From This ? in the 5.0 Mustangs Forum. I finally got my motor broken in and I'm taking the car to the ...
Old May 4th, 2007, 07:58 PM   #1
I finally got my motor broken in and I'm taking the car to the dyno next friday.
Heres my question:
My brother has an 88 lx and his car made 340rwhp/ 350rwtq with a 306ci, 11 to 1 compression, AFR 185cc heads, X303 cam, TFS track-heat intake, 70mm TB, 75mm MAF, 1 3/4 longtubes, 30lbs, ext........
My car has a 306ci with 12.2.1 compression, AFR 185cc heads port matched to intake & exhaust, 620 lift lunati cam, TFS R intake, 75mm TB, 75mm MAF, 1 3/4" longtubes port matched to exhaust side of heads
Would my car make alot more horsepower than his or will it be just close?
Old May 4th, 2007, 11:54 PM   #2
ujslost's Avatar
personally i think you got to much cam and you should have went with a 165 head instead of the 185
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801
Old May 5th, 2007, 12:26 AM   #3
TurboLX's Avatar
1990 Mustang LX Turbo
8.67@165.91 mph
yea thats a serious cam you got there
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info
Myspace
Small Block Posse
Old May 5th, 2007, 12:39 AM   #4
Stangzilla's Avatar
Yeah the cam is way to much but I think he will be ok with the AFR 185's because of the high compression he has.. You gonna be able to run pump gas with that?
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old May 5th, 2007, 07:35 AM   #5
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Re: Any Horsepower Gains From This ?
Heres my question:
The lift of the cam doesn't really say much. What are the rest of the specs? How did you come up with the compression ratio?
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old May 5th, 2007, 12:26 PM   #6
that's "A LOT" of lift... For a 306ci, you dont need that kinda cam or those heads. Maybe if it was a 347 stroker, then those mods might be all nice and well, but your choice of parts dont match or complement each other.
Old May 5th, 2007, 03:11 PM   #7
Lunati 51018 Cam:
242/ 252 Duration @0.050
560/576 Lift w/1.6's
599/ 619 Lift w/1.72's
110 LSA
The pistons are TRW L2249N. They have a 13.1.0 ratio with 54.5cc heads, 12.2.1 with 58cc, 11.0.1 with 63cc
Its runs on straight VP 110
Old May 5th, 2007, 10:18 PM   #8
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Cubic inch is only one part of the equation........and a very small part at that.
Old May 5th, 2007, 10:23 PM   #9
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Lunati 51018 Cam:
110 LSA
That cam will work with that set up. I wouldn't go buy what the box says for compression. You really need to calculate it. It should be relatively close to what the box says though. Make sure your gearing (and converter if you have an automatic) match the power range of the engine. You are going to need an aftermarket EFI system or piggyback if you are still running EFI because you will need to spin that thing over 6250 rpm.
Old May 5th, 2007, 11:41 PM   #10
neverfastenough's Avatar
Yeah, I don't think they factor in the thickness of the gasket or the volume around the outside of the piston down to the first compression ring, but like he said it is probably pretty close.
Old May 6th, 2007, 12:43 AM   #11
Stangzilla's Avatar
Lunati 51018 Cam:
110 LSA
He can also can use an RPM extender if he dont want to spend the $$ on the other things
Old May 6th, 2007, 05:20 AM   #12
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Yes he can. The RPM Extender falls into the "piggyback" category.
Old May 6th, 2007, 09:55 PM   #13
Stangzilla's Avatar
Ahh did not know that thanx Darrell...
Old May 6th, 2007, 10:59 PM   #14
83five0's Avatar
1983 GT
UNKNOWN
ive always thought that the bigger the ports on the heads the more you flow in and out, and that the cam, intake, and other parts should all match or be pretty close to the same rpm operating range. but cubes didnt really matter that much. with that high compression and that much lift that motor should be thuppin. i got 10.1:1 pistons in my 4.3 and a 16* advance timing and i have to run premium or it pings.
1983 FOX BODY-LIL SOMTHIN IN PROGRESS
Threads Similar to: Any Horsepower Gains From This ?
gains? SantanielloITA V6 Mustangs 5 November 6th, 2007 12:08 AM
h/p gains? haywood11 5.0 Mustangs 11 September 27th, 2007 10:11 PM
HP gains. bbrewer03 96-98 9 September 22nd, 2007 06:39 PM
Real MPG gains on 5.0? Scrapdaddy SR. 5.0 Mustangs 7 May 17th, 2007 07:40 PM
Horsepower Gains sonicblue 99-04 5 September 19th, 2006 12:44 PM
