Clutch pedal??????
Old April 29th, 2011, 11:39 PM   #1
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
Clutch pedal??????
Ok so I'm really confused right now, how does a clutch pedal return to its position after its pressed in?
Is there a spring on the clutch pedal assembly itself or on the clutch fork to the transmission?
Please respond ASAP
Thanks in advance.
Old April 30th, 2011, 12:49 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
Clutch pressure plate
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 30th, 2011, 01:53 AM   #3
1992 Lx
11.39@119.24
what that dude with the hot wife said
Old April 30th, 2011, 05:28 AM   #4
brandon444's Avatar
91 Mustang LX 5.0
Alright so the cables attached to the fork then to the quadrant, and the pedal will go back to the original position?
I'm just a little confused on how the clutch pedal and it engaging and disengaging works.
Old April 30th, 2011, 11:52 AM   #5
nxcoupe is on a distinguished road
The pedal just hangs there. The springs that apply pressure to the clutch disc require pressure to compress when you push the pedal in. When you release the pedal, the pressure plate releases the springs and they push against the disc to the flywheel. It will only return as far as the cable and adjuster will allow.
90 GT 393 5 spd, 467 rwhp 480 rwtq
92 coupe, R/S 308 5 spd
93 coupe, 2.3 5 spd
Old April 30th, 2011, 04:10 PM   #6
ryanw's Avatar
Lol....my wife got a kick out of your comment.. Ha ha
255 fuel pump,
3:27 gears
Threads Similar to: Clutch pedal??????
clutch pedal 4.6DreameR 99-04 5 November 16th, 2010 08:32 PM
clutch pedal vibration and excessive clutch chatter mscribellito 99-04 13 August 19th, 2010 04:59 PM
Clutch pedal 91 fox 5.0 Mustangs 2 October 4th, 2009 08:12 PM
clutch pedal cmdr_anomic 2005 - 2010 3 May 22nd, 2008 08:39 AM
clutch pedal.... the real shocker 99-04 36 April 9th, 2008 12:10 AM
