1991 Mustang GT
Brake help
So I got in my car today and the brake pedal went to the floor with no resistance. I checked my MC and it is pumping fluid. Does this mean I must bleed my brakes? Thanks for the help
93 5.0 lx
Check for leaking brake fluid. My gf's stang did the same thing, a rusty brakeline broke, good thing we were only a half mile from her house
1991 Mustang GT
I don't see any fluid leaking from anywhere
1991 Mustang LX 5.0
Look inside your rims from the backside for fluid, especially the rear ones. The wheel cylinder seals are known problems on these cars.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Mustang GT
Hmmmm...still I don't see any fluid. Even behind the wheels
Check your master cylinder. Might be shot, also check your vacume lines going to the unit.
1990 mustang gt
Have you been working out your legs
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1991 Ford Mustang GT
Remove the wheels and look for leaks at the calipers in the front and wheel cylinders in the back. Check all brake lines from the MC to the tire they go to. If you don't see any fluid at all you should be able to pump up the brakes to build pressure. If you can't do this I'd replace the MC and brake booster (might as well replace both) and then bleed the brakes.
1991 Mustang GT
Ill try this today. Thanks guys. Ill keep you updated
Threads Similar to: Brake help
| new brake rotors installed, equals new brake problem | StutteringStang06 | 2005 - 2010 | 23 | December 16th, 2009 06:58 PM |
| Baer brake upgrade -- parking brake not working | spoulson | 5.0 Mustangs | 0 | September 30th, 2009 02:01 PM |
| Alpine IVA-D310 foot brake and e brake switch ?s | 97Cobra | Audio/Video | 2 | February 2nd, 2008 07:31 PM |
| Brake light switch problem after upgrading brake booster | black88 | 5.0 Mustangs | 2 | January 20th, 2008 11:41 PM |
| Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits | OcOnnor220 | Modular Mustangs | 2 | July 8th, 2007 12:36 AM |
