#21 |
Traction...?
1996 GT/ 2008 GT Vert
Check grounds, check battery terminal for corroding, fuse box, and possibly the ignition switch. Do you have interior lights when you open the door?
#22 |
nope. no lights at all. no electrical. sucks. haha. im going to replace the ignition block on the column tomorrow.
#23 |
89 GT
Yep, you got the right approach. Just throw money at it until it's fixed.
#24 |
If you have no lights its not ignition or your computer. Your headlights or hazard lights dont work? If not like they said it has to be a ground or maybe a fused link.
#25 | |
1991 Ford Mustang GT
#26 |
problem solved. got sold a faulty solenoid.
