1989 mustang gt
Horspower of new engine
I have just built and installed a new engine in my 89 5.0. i was curious of the approx. HP. im gessin about 300 but would like some other opinions.
85 block bored .060 over. Badger pistons flat top with valve reliefs.( not sure of compression ratio.) Stock crank Edelbrock performer rpm heads with 2.02 intake and 1.6 exhaust valves roller lifters ford racing F cam 1.6 roller rockers BBK 1-5/8" long tube headers and x pipe into flowmaster 40's into 2.5" tail pipes. self ported stock upper and lower intake. underdrive pulley kit. no a/c no smog pump electric fan high output coil stock distributor 24 lb. fuel injectors stock throttle body with 65mm bbk throttle body spacer. stock mass air flow meter. I know i should upgade the intake and mass air and throttle body and i will. Im just curious to know approx what it is making now for HP. Thanks for your input. |
1992 Lx
11.39@119.24
255whp
1989 mustang gt
doesnt it make 225 WHP bone stock? or is that at the crank? 255 WHP just seems a little low to me. What's holding this thing back?
1992 Lx
11.39@119.24
shitty intake and cam
93 5.0 lx
+1 everything hatch said
1992 Lx
11.39@119.24
cars make 190whp or so stock
1989 mustang gt
What suggestions do you have for intake and cam? will that get me to 300 HP?
1992 Lx
11.39@119.24
ehh you wont need alot of intake your heads dont really flow shit, cam isnt something I know enough about to suggest. Lots of lift square lobes
1989 mustang gt
Guess i was hoping for more. I got the block assembled with pistons in it and the heads all for $1000. Cant really complain. Maybe a little forced induction will help her out. I have 2 comp cams for sale Non roller if anyone is interested.
Part #'s 31-246-3 and 35-242-3 |
Threads Similar to: Horspower of new engine
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Can U smell the Horspower in the air yet? | G.T. Rags | The Clubhouse | 24 | March 21st, 2008 04:11 PM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
