85 block vs 89 block
Old May 1st, 2011, 10:45 PM   #1
backusbs's Avatar
1989 mustang gt
backusbs is on a distinguished road
Ive heard all kinds of things about the different year blocks. I have an 85 roller and a 89 roller. which is better?
Old May 1st, 2011, 11:59 PM   #2
fogged306's Avatar
89 GT
Both the same as far as strength goes. Not sure, but the 85 may not be tapped for the lifter hold down for roller lifters.
Old May 2nd, 2011, 12:40 AM   #3
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
The 85 is a roller block? I didnt think they had roller blocks in 85. If you have a flat tappet 85 block vs a roller 89 block the difference with the same setup would be about 20-30 horsepower and a longer life in favor of the 89. The roller lifter allows the cam to have a longer arch on it causing valves to stay at max lift longer producing more power. In order to put a roller cam in a non roller block you need to either have the lifter ports ground down to allow the use of the spider, or use special roller lifters that have a link bar on them keeping them from turning.
Hope I was right on all that.
Old May 2nd, 2011, 12:53 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
85 mustangs had roller cams(blocks), if im remembering right and i do believe it was the first year for mustangs
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 2nd, 2011, 12:55 AM   #5
Ohsplat's Avatar
1983GT
No motor or trans
should be no difference then.
Old May 2nd, 2011, 01:10 AM   #6
ryanw's Avatar
yep i was right 85 mustang first year of roller cam, I should have know for a fact do to me owning an 85gt, but i pulled this out as proof any ways
Another new grille design came along for the 1985 model year featuring a single large slit between the two pairs of headlights. The GT was treated to a new set of 15-inch cast-aluminum wheels shod with P225/60VR15 Goodyear Eagle "Gatorback" tires, and thanks to a serpentine single belt accessory drive system and revised roller cam, the 5.0 HO engine was now making a full 210 horsepower in four-barrel carbureted form.
255 fuel pump,
3:27 gears
Old May 2nd, 2011, 01:18 AM   #7
Ohsplat's Avatar
1983GT
No motor or trans
heheh a FULL 210! Wish we were back in those days when 210 was alot. Hell the new scion has a 190hp naturally aspirated 4 banger this year. The mustang V6 is at 300hp. gonna take alot to get my 83 up to par with a new gt LOL.
Old May 2nd, 2011, 01:21 AM   #8
ryanw's Avatar
well the 84gt mustang only had like 165hp so it was a good jump in power...lol
255 fuel pump,
3:27 gears
Old May 2nd, 2011, 01:34 AM   #9
Ohsplat's Avatar
1983GT
No motor or trans
mines a 83
Production Numbers:
66B 2dr Sedan: 33,201
61B 3dr Hatchback: 64,234
66B 2dr Convertible: 23,438
Total: 120,873
Available Engines:
2.3L 2V 4cyl 88hp
2.3L EFI 4cyl 145hp (Turbo GT)
3.8L 2V V-6 112hp
5.0L 4V V-8 175hp <---- Gigiddy gigiddy!
Old May 2nd, 2011, 01:40 AM   #10
ryanw's Avatar
Originally Posted by Ohsplat View Post
mines a 83
Production Numbers:
Total: 120,873
Available Engines:
2.3L 2V 4cyl 88hp
3.8L 2V V-6 112hp
Here read this....its real nice info, i posted it last year
fox body history
255 fuel pump,
3:27 gears
Old May 2nd, 2011, 01:52 AM   #11
Ohsplat's Avatar
1983GT
No motor or trans
So the 83 was the first 5.0 HO, and the 1st year to offer the T5. Mine however Has a 4speed in the trunk. doubt ill use it.
Old May 2nd, 2011, 02:09 AM   #12
ryanw's Avatar
naw...82 first H.O...if you really wanna call 157 Horse power an H.O.......lmao
255 fuel pump,
3:27 gears
Threads Similar to: 85 block vs 89 block
short block's block vrs block in car stock? adrenaline=lifeline 99-04 7 August 19th, 2008 08:22 AM
long block or short block? jRoush 5.0 Mustangs 26 January 26th, 2008 05:35 AM
Boss block or Dart block??? JONJON 5.0 Mustangs 48 November 6th, 2007 09:37 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 10:57 PM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 01:31 PM
