351 vs 302 with same parts.....
Old May 2nd, 2011, 12:34 AM   #1
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Please stay on topic as I am still deciding which engine to build. I do not care about center of gravity, or weight.
So the question.. I am asking for a ballpark est of both of these engines horsepower built as an economy build with these parts.
Gt40p Heads
Victor Jr intake
stock HO cam
1.6 roller rockers
balanced crank, pistons, rods.
Holley 600 cfm carb
Both the 351 and 302 would be roller motors.
Old May 2nd, 2011, 12:36 AM   #2
1992 Lx
11.39@119.24
random combo. 302 would prob be faster due to getting more rpms so outa said crappy combo so you can gear it steeper
Old May 2nd, 2011, 12:41 AM   #3
fogged306's Avatar
89 GT
Stock HO cam, 600cfm carb, and GT-40 heads are going to choke the shit out of a 351. That vic jr on that combo isn't helping. That is a pretty big mismatch you got there. I agree, probably better on a 302.
Old May 2nd, 2011, 12:44 AM   #4
Ohsplat's Avatar
1983GT
No motor or trans
Cool. this is basically the parts I have laying around the house. So if i stepped up to a 750 double pumper and a torqer2 would that help? I have those as well
Old May 2nd, 2011, 12:48 AM   #5
ryanw's Avatar
1991 Ford Mustang GT
750 seems a little big to me but I'm not a carb man, but if i had to take a guess id think 650 would be more up your alley on a 302, but i may be wrong
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 2nd, 2011, 12:49 AM   #6
fogged306's Avatar
89 GT
If you put the right cam in that, you could put those on the 351 and be in decent shape. You'd still be choking the cubes with those GT-40's, but it will be better than the first combo on either deck block... you do know that you can't use an intake for a 302 on a 351 and vice versa right?
Old May 2nd, 2011, 12:59 AM   #7
Ohsplat's Avatar
1983GT
No motor or trans
Yeah i know about the intakes. I have like 6 carbs that came in this mustang when I bought it lol. I would replace the GT40s at some point with twisted wedges but this is just to get me running. Any idea on what the 351 would have in HP with the 750cfm torqer2 and gt40s?
Old May 2nd, 2011, 09:47 AM   #8
Proud American
MustangMatt96GT's Avatar
You would probably put right around 270-280 horse to the ground... Corrected SAE numbers... Infact im building the exact engine right now with my buddy and it will never get on the dyno, but it will have track numbers....
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 2nd, 2011, 10:29 AM   #9
I would say rock a stock motor until you can save enough fundage to throw a set of good heads on the 351 shortblock because its not worth the swap with those parts in my opinion.
Old May 2nd, 2011, 10:46 AM   #10
Stdyhand is on a distinguished road
IF this is only to get you running but you plan to mod it later I'd say go with the 351. It will already be in the vehicle and you can add heads and a cam later.
If you don't think you'll be modding it too much I'd say go with the 302 for a little less weight and probably a little better fuel economy if that means anything to you.
Either way your going to start off with 302 power with that combo. Now you put a set of heads and cam in that 351 later and you'll produce much more power.
Old May 2nd, 2011, 12:05 PM   #11
Ohsplat's Avatar
1983GT
No motor or trans
Thanks for all the info. I look forward to seeing those track numbers when you get that engine in! I think I will do the 351. I have no engine in at all now so to swap in a 351 wont be much more work then putting in a 302.
any idea of which headers to use with a 351 and P heads in a mustang?
Old May 2nd, 2011, 12:23 PM   #12
BBK unequal headers work on the gt40's and clear fine. You will have a limited selection with the gt40p heads. You might find some fairly cheap if you shop around.
Old May 2nd, 2011, 12:32 PM   #13
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
A Vic jr will raise the CG and you'll tip over
A 750 dp is too big for that. For the combo you listed, I think you'd be better off with the torquer II, and the 650. Unless you're planning on making 450+ at the tires, it'll be cheaper to stick with the 302, and it wil be sufficient. When you go to buy new heads, you can get away with TW170s, and not have to buy the larger, more expensive heads for a 351. Just my opinion.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old May 2nd, 2011, 12:40 PM   #14
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
^^ The whole getting it running thing is cool if your going to buy heads later, but a 170 twisted wedge is def NOT enough for a 351 based motor.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 2nd, 2011, 02:58 PM   #15
^ I agree with these two guys... if your goal is 302 power then go with the 302 shit's cheaper
Threads Similar to: 351 vs 302 with same parts.....
Parts reviews for aftermarket mustang parts... topflitecop21 Modular Mustangs 3 February 22nd, 2009 10:18 PM
