Rear main seal leak will i pass tech inspection??
Old May 3rd, 2011, 09:26 PM   #1
black88's Avatar
1988 Mustang GT Hatch
black88 is on a distinguished road
my rear main seal was leaking so i decided to change it. In the process i discoverd that my crank is scored. I installed the Felpro Teflon $40 Seal. It still leaks i think it leaks more. Anyone know if i went to the track would i pass tech inspection?
306, Edelbrock performer RPM Heads, Edelbrock Performer RPM 2 Intake, E303, Flowmaster Cat back, H-Pipe,373s, 24 Pound injectors, Cold air, 75mm Mass air, 70mm TB,255lph fuel pump,underdrive pulleys,B Springs,5 Lug Conversion,Cobra Wheels
Old May 3rd, 2011, 09:40 PM   #2
Proud American
MustangMatt96GT's Avatar
At my track you would pass. Unless its pouring oil out... Mine just leaks a bit, but still never have to wipe it up after sitting at the staging lights.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 3rd, 2011, 11:01 PM   #3
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
Mine leaks a quarter size every couple of weeks or so. They don't even look at our track. If it leaks a lot, make it right before you go next.
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old May 4th, 2011, 07:15 AM   #4
black88's Avatar
Anyone ever hear of an offset rear main seal that changes where the seal rides on the crank?
Old May 4th, 2011, 04:32 PM   #5
black88's Avatar
Anyone?
Threads Similar to: Rear main seal leak will i pass tech inspection??
Possible Rear Main Seal Leak??? wrr1020 99-04 4 April 4th, 2011 09:16 PM
Rear Main Seal 02GreyStallion V6 Mustangs 16 January 21st, 2011 01:58 PM
will i pass tech inspection Danderson Drag 2 September 25th, 2010 09:53 PM
Think this will pass tech inspection at a dragstrip? Avengence 2005 - 2010 8 August 26th, 2009 01:17 AM
Rear Main seal 1gunner23 5.0 Mustangs 5 May 11th, 2006 11:53 PM
