302 clutch on a 351w
Old May 3rd, 2011, 10:15 PM   #1
holset35's Avatar
1986 LX NOTCH
holset35 is on a distinguished road
Here we go will my 302 clutch and pressure plate wont work on my 351 flywheel.I thought they worked together but guess not but i cant find enough info go off of.
86 TRUNK
359w-SRP 8:1-GT40Ps-X303-MAC LONGTUBE'S-VICTOR JR INTAKE-850 HOLLEY-T-5-410's-150 shot
Old May 3rd, 2011, 10:21 PM   #2
fogged306's Avatar
89 GT
They will work. The only difference between a roller 5.0 and a 351 is the flywheel is a different weight balance.
Old May 4th, 2011, 11:13 AM   #3
holset35's Avatar
1986 LX NOTCH
I bought a flywheel and the clutch and pressure plate wont bolt up
86 TRUNK
Old May 4th, 2011, 11:23 AM   #4
fogged306's Avatar
89 GT
How many tooth flywheel did you buy? What size is it?
Old May 4th, 2011, 09:55 PM   #5
holset35's Avatar
1986 LX NOTCH
Thanks for the insight I called summit tech and questioned the crap out that guy so I cut my losses and bought the 28oz billet flywheel from ford racing it specialy made for a 302 clutch on a 351w block.
86 TRUNK
Old May 4th, 2011, 10:00 PM   #6
fogged306's Avatar
89 GT
There's really no such thing as a specialty flywheel for this application. Just different balance ones. The bolt pattern for the flywheel bolts are the same and the size and amount of teeth on the flywheel dictate what bellhousing it will fit in. A 28oz 157 tooth flywheel should be the same for a 351 or a 302 provided the 302 had a 28oz crank. Those guys at the summit techline know how to bullshit so hopefully you didn't buy a billet flywheel just because the guy told you that is the only one that will work.
Old May 4th, 2011, 11:45 PM   #7
1965 Mustang Coupe
ajzride is on a distinguished road
Send a message via AIM to ajzride
Actually there are at least two different bolt patterns for the pressure plate on a 164 tooth (and supposedly 157 tooth although I can't verify that from experience) 28oz flywheel. I know this because I ordered the wrong one and it wouldn't bolt up. Called the guys at ZOOM and they hooked me up with the right part number. I wish I knew which applications were different so that in the future I could help other people avoid the same mistake, but I can't find anyone to tell me. Perhaps another member here could shed some light.
Threads Similar to: 302 clutch on a 351w
clutch pedal vibration and excessive clutch chatter mscribellito 99-04 13 August 19th, 2010 04:59 PM
Gt40 intake 351w or Trick Flow 351w Tyler2009 5.0 Mustangs 3 January 27th, 2010 09:40 PM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 12:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
