Canary yellow 1990 GT
Praying for 11's after winter mods
My dilemma
Got my car last week and drove it pretty much all week before I had to leave town. It's been sitting for a better part of 3 or 4 years, being driven minimally. I noticed when I picked it up there was some valvetrain clatter. (Yeah I probably should have taken the time to adjust it but didn't really have time to dive in real deep on the car since I had been gone 2 months, home for a week, and out of town until who knows when.) I noticed at about 5300 rpm according to the factory tach it will get a pretty noticeable knock on the passenger side (sounds like anyway) but then go away at about 5500. I figure it was just something out of wack in the valvetrain so i just quit revving it that hard. No knock when it returns to idle, and gauges look fine during and after it. The more I got to thinking the more i realized the only other 2 engines i heard with a high rpm knock like that needed a cam. I'd like to bring the car down to Alabama but won't if it does indeed need a cam. My next thing is, I don't want to throw a cam in it to enjoy it for the summer just to tear it back apart this winter to put a bigger one in it when I plan on doing my winter mods, nor will I have time to. HELP!!!
-Edelbrock Performer Intake/Heads -TFS2 Cam -Tremec 3550 -All them other bolt on performance thingys |
89 GT
Do you have a dial indicator and base?
And is it definitely a knock, or more of a tick? A knock usually means rod bearings. |
1992 Lx
11.39@119.24
did you say cam went bad wat
I would consider it a knock tbh. It never loses oil pressure or anything though. Isn't that the first sign of a bearing cashing in? I'm new to this whole troubleshoot and actual diagnostics thing. In the old trucks we used to run you'd just run it until it wouldn't turn over and go buy another scrapyard 350 for $200.
89 GT
If you are going by the stock gauges, you can't really be sure of anything. They're not very accurate. I've also seen engines with 10lbs at idle run for years. I've had one myself that would idle under 15lbs when it was warm and it ran until I sold it like that and I never had an issue. If you have 0 lbs, then yes, definite sign of main bearing failure. Can't say I've ever had a rod bearing go and checked the oil pressure though. Rod knock is a very definitive sound and once I hear it I know exactly what's wrong. If you've heard it once, you'll know exactly what it is every time you hear it after. Piston slap does sound very similar, but you usually get that on a cold engine.
Easy way to check is to pull your oil filter and cut it open. Bad bearings will look like gold flakes in the filter pleats and around the casing of the filter. |
#6 | |
89 GT
Detonation will sound more like marbles in a can than a knock. Kind of tough to diagnose without actually being there ya know. Any mechanic should be able to listen to it and give you an idea of what you have going on. Short of pulling the valve covers and taking a look and checking the torque on all your rockers, and checking your oil filter, I couldn't really give you much else to look for.
#8 | |
#9 | |
89 GT
Worst case, you can find a shortblock on craigslist or the junkyard for less than $300 to slap in until you do something different.
#11 | |
Just throw an LS series motor in it and be done!
Not quite prepared to go that route yet.... That's my final plan though.
Was looking back over something and realized i didnt see this post
![]() Yeah I said cam went bad, youve never seen a rounded off lobe?
1992 Lx
11.39@119.24
never seen it happen in a hydralic roller
Didn't realize these were hydraulic roller motors. Guess the odds are pretty slim then?
1992 Lx
11.39@119.24
very
Ah geez fuck. It just doesnt sound like something in the bottom end. Maybe ill pray for a bad lifter now
1992 Lx
11.39@119.24
Ive heard bone stock foxes ping and have valve float
Stock heads that have been worked and a pretty small cam. Maybe that's the culprit. My brother said it sounded like a floating valve as well, but it never really quits pulling.
Threads Similar to: My dilemma
| Dilemma | MC Lovin | 5.0 Mustangs | 13 | March 11th, 2010 01:16 PM |
| Serious Dilemma | zinc02GT | The Clubhouse | 31 | March 23rd, 2009 03:49 PM |
| dilemma | GoodOleBoyzRacin | 5.0 Mustangs | 23 | December 9th, 2008 03:05 PM |
| Dilemma | zinc02GT | 99-04 | 6 | October 22nd, 2008 04:09 AM |
| serious dilemma | gooberhead320 | The Clubhouse | 38 | June 27th, 2008 02:13 PM |
