idk where to go - Page 3
Old May 8th, 2011, 06:13 PM   #41
fogged306's Avatar
89 GT
If you don't do some tuning, you're playing with fire on a stock block. IMO.. at the very least, do some proper plug reading and adjust accordingly with fuel pressure and timing.
Old May 8th, 2011, 06:45 PM   #42
FastStang91Lx's Avatar
1991 Mustang LX 5.0
No tuning and running close to 'known' block limits isn't the greatest idea in the world. But, an air/fuel ratio gauge could be your friend. I initially planned on using my MSD Digital 6 box to retard timing when spraying, but the tuner said he would just burn me a second tune on the chip. If you plan on only running this combo for a short time, I understand why you wouldn't wanna drop 500 on a tune, but remember, at most places around here they say 300 of the tune is the chip. Once you've bought it, you own it. Retunes run around 80 to 150 here depending on the amount of time it takes. You could/should talk with a local tuner in your area to see what your options are.
Old May 9th, 2011, 01:41 AM   #43
ryanw's Avatar
1991 Ford Mustang GT
Originally Posted by FastStang91Lx View Post
Having a 4 month old around slows things down a little
Tell me about it....I know how it is bro, im in the same boat..
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 9th, 2011, 03:15 AM   #44
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
Yeah, if thats the case that'd be pretty reasonable. I wish I could just use my SCT from my 02. :/ So even if I ran a 100shot, its a no go? Just wondering because I know with the newer cars tuners will tell you to not worry about it unless you want to stretch out every little pony you can.
I just wanna have a little fun in this car before winter hits. Doesn't have to be anything huge.
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old May 9th, 2011, 07:17 AM   #45
fogged306's Avatar
89 GT
If you do the kit right and you read your plugs, you can do a shot of nitrous. But you have to make sure you read the plugs right. Get the set-up running and take it somewhere where you can do a good nitrous run and immediately after you let off the throttle, shut it down, pull over, and pull a few plugs and take a look. Better to do this at the track so you don't have to worry about coasting with no power steering. Also make sure to only push the brake pedal one time after you're coasting. After once or twice, the pedal will be hard as a rock and tough to slow down. The reason you do this is because any idle time after the run will skew the results of reading the plug. You want it fresh from the run to know what's going on.
Old May 9th, 2011, 05:28 PM   #46
BadBlackGT's Avatar
13.82@100.26
Yeah I gotcha. And checking the plugs, i'm guessing i'd be looking for a wetter plug that doesn't have any white-ish haze residue correct?
Just hope my first run won't look like this lol.
Old May 9th, 2011, 06:09 PM   #47
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Those wings are usually for cars that trap over 150 mph. Granted a stock car can backfire, but not as often. Dont worry dude.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 9th, 2011, 06:15 PM   #48
BadBlackGT's Avatar
13.82@100.26
Haha jokes jokes, I know my range of error isn't near as narrow as theirs. Just a mild setup shouldn't be too too hard on it hopefully haha. I'll keep ya'll posted, bout to do a tear down and see where she sits.
Old May 9th, 2011, 06:54 PM   #49
1993 5.ohhhh
12.97 @140mph
Good luck, take pics.
Old May 9th, 2011, 09:25 PM   #50
ELEX's Avatar
1989 LX
9.14
ELEX is on a distinguished road
Sell it and buy mine.
My Ferd is a turd.
89 notchback
79 notchback <- new addition
Old May 9th, 2011, 09:47 PM   #51
1993 5.ohhhh
12.97 @140mph
7700 for a coupe with rust damnnnnnnnn. Dart block? Ysi or t trim?
Old May 11th, 2011, 12:11 AM   #52
BadBlackGT's Avatar
13.82@100.26
Well finally got around to getting the engine out and down to the bare block. Everything seems to be okay from first glance. Didn't see any problem spots, just a ring and bearing job hopefully. I'm going to clean it all up tomorrow and check it out real good and get my dad to overlook it as well as lathe the crank and see if its well balanced.
