New floor pans in
Old May 6th, 2011, 12:10 AM   #1
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
New floor pans in
Entire pan
Close up of beads, and seal.
Welded on a new strut tower
someone jacked car up under rear seat, jack went thru floor. Welded it shut.
Seat bolt that broke.
Old May 6th, 2011, 12:17 AM   #2
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
you need to learn how to weld... just sayin
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old May 6th, 2011, 12:18 AM   #3
Ohsplat's Avatar
1983GT
No motor or trans
1st time lol
Old May 6th, 2011, 12:20 AM   #4
1992 Lx
11.39@119.24
just buy a 1500 dollar roller....
Old May 6th, 2011, 12:20 AM   #5
ryanw's Avatar
1991 Ford Mustang GT
why is every thing all rusty
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 6th, 2011, 12:21 AM   #6
Ohsplat's Avatar
1983GT
No motor or trans
leaky sun roof the last guy never fixed.
Old May 6th, 2011, 12:24 AM   #7
Ohsplat's Avatar
1983GT
No motor or trans
What fun is that? lol.. Find me a original 83 gt for 1500. I think at the end of the floor pan I started to get used to the welder.
Old May 6th, 2011, 12:28 AM   #8
1992 Lx
11.39@119.24
weld in the rain
Old May 6th, 2011, 12:30 AM   #9
Ohsplat's Avatar
1983GT
No motor or trans
weld in the rain
Was hard enough as it was. I used the cheap flux wire that came with the welder, now that I am used to it i can lay a bead much better.
Old May 6th, 2011, 12:31 AM   #10
ryanw's Avatar
your going to grind down all you welds and remove all that rust....Right ?
255 fuel pump,
3:27 gears
Old May 6th, 2011, 12:34 AM   #11
Ohsplat's Avatar
1983GT
No motor or trans
Grind them down, use joint sealer, primer, roll on bed liner. undercoat bottom. Car must have been in a pretty back crash at one time, so i welded on all new parts on the driver side. Fender skirts, shock tower, supports.
Old May 6th, 2011, 12:35 AM   #12
Digsj7's Avatar
1993 Mustang LX
weld in the rain
I have a feeling you aren't gonna lay shit with that welder! Don't worry about a helmet either...shits overrated
Old May 6th, 2011, 12:37 AM   #13
1992 Lx
11.39@119.24
squint! why do you think asians dont weld them? Ive never even seen a nicer 83
Old May 6th, 2011, 12:37 AM   #14
Digsj7's Avatar
1993 Mustang LX
Should have just bought my "almost" rust free coupe
Old May 6th, 2011, 12:38 AM   #15
Digsj7's Avatar
1993 Mustang LX
I always think I'm gonna burn my contacts to my eyes!
Old May 6th, 2011, 12:44 AM   #16
Ohsplat's Avatar
1983GT
No motor or trans
Sarcasm? lol.. well i could spend a few k on one already done but I like to do the work, learn how to do the work, and feel I actually restored something you dont see as many of. Not many 4 eyes on the road these days and the ones I have seen were 4 or 6 bangers.
Old May 6th, 2011, 12:46 AM   #17
Digsj7's Avatar
1993 Mustang LX
Just giving you shit man.
Keep it up and next time you decide to "lay a bead"...practice on some scrap first.
Old May 6th, 2011, 01:00 AM   #18
Ohsplat's Avatar
1983GT
No motor or trans
Yeah I should have, but i knew I was gonna grind the beads flat anyhow...From underneath the car it looks factory.
Old May 6th, 2011, 01:02 AM   #19
1992 Lx
11.39@119.24
sorry didnt mean nicer, I mean nice. Never seen a fox that old in decent shape
Old May 6th, 2011, 01:10 AM   #20
Ohsplat's Avatar
1983GT
No motor or trans
the part that boggles my mind is the dent in the center hump where the shifter comes thru the floor. Also a hole in firewall where it looks like the heads went into it. This one is a bit blurry but between the 2 real bright spots is a huge dent. Im starting to think the drive train broke loose at one time.
Threads Similar to: New floor pans in
Searching for floor pans keyba 5.0 Mustangs 0 April 28th, 2011 09:09 AM
1968 floor pans and front frame rails banaszak Classic Mustangs 0 October 30th, 2010 03:23 PM
My floor pans are cracked ponyrides 5.0 Mustangs 0 March 25th, 2010 10:00 AM
floor pans Echo_7 Classic Mustangs 8 March 12th, 2010 09:43 AM
Oil pans? bansheex 94-95 2 March 16th, 2009 01:57 PM
