TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam - Page 2
LinkBack (1) Thread Tools
Old May 7th, 2011, 07:21 AM   #21
fogged306's Avatar
89 GT
Originally Posted by FastStang91Lx View Post
From what I always read from the benchflow people on here is that the AFR 185's outflow the mid range, but the tf170's had more cfm in the higher lift. Or was it vice versa? Either way, both are comparable heads with one being an inline. As far as the CNC'ing on the AFR's, it's available in two versions. One more rough, and one more smooth, from what I remember from back in the day.
I think it's the other way around. Every chart I've seen has the AFR's flowing very well up top. Problem is, I've never seen a AFR flowed on a 4" or 4.030" bore. It's always on a 4.125" bore where valve shrouding isn't an issue.
Old May 8th, 2011, 01:14 AM   #22
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Hmmmm..... sounds like fudging numbers to me.
Old May 8th, 2011, 03:05 AM   #23
dennislv's Avatar
90 GT
dennislv is on a distinguished road
Is this setup (tw170s, tf stage 2 cam & tf intake) safe for say a 100 shot on the stock bottom end? What would be a safe amount? Thanks...
Rewarding our friends, punishing our enemies.
Old May 8th, 2011, 08:58 AM   #24
fogged306's Avatar
89 GT
Yep. They like to hide the fact that their inline head shrouds the valve on the stock bore engines. Lots of people mislead by that garbage. Still a good head, but not as great as they make it sound on a 4" or 4.030" bore.
Old May 8th, 2011, 09:20 AM   #25
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
100 shot would be fairly safe, with a good tune.
Fo sho
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old May 8th, 2011, 12:33 PM   #26
dennislv's Avatar
90 GT
So with my setup, would a TW185 be too big? I eventually wanna stroke it to a 347 and would rather buy once if possible.
Thanks...
Old May 8th, 2011, 01:11 PM   #27
fogged306's Avatar
89 GT
You'll need the right cam if you're still 302 cubes. Too much intake duration and it will be lazy. You need something with decent lift and shorter duration on the intake to keep cylinder pressure up when using larger heads like that on a smaller cube engine. The OEM's have been doing it for a while now, so you don't need to worry about having too much head for your 302 as long as the valve events are correct. I would talk to a cam grinder about a cam if you run those heads on your engine. Done right, it'll scream. Wrong cam and it can be unimpressive.
Old May 8th, 2011, 05:03 PM   #28
1991 Mustang LX 5.0
My combo is 306, tw 185's track intake, stage 2 cam and flat top pistons. Great heads for the 347 future stroker that I WAS going to do before I decided to go 351/408. Going to send mine out in the future.
Old May 8th, 2011, 10:51 PM   #29
dennislv's Avatar
90 GT
So I'm kind of confused here...
Trick Flow Specialties TFS-51400015 - Trick Flow® Twisted Wedge® Track Heat® 190 Cylinder Heads for Small Block Ford - Overview - SummitRacing.com
with
Trick Flow Specialties TFS-51402001 - Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L - Overview - SummitRacing.com
Would be ok or no? I'm going to Summit Tuesday morning and don't wanna fuck up.
I also have a 100 shot nitrous kit I want to use eventually.
Are the 190's too big? Should I go with the 170s? The price difference between the 170's and the 190's is like $150 whereas he 185's are like $500 more than the 170's.
Thanks...
Old May 8th, 2011, 10:51 PM   #30
dennislv's Avatar
90 GT
Keep in mind its a 306 with a stock/standard bottom end.
Old May 8th, 2011, 11:02 PM   #31
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I don't think that cam is right for the larger heads (FAC190s, or the TW185s). IMO, you'd be best to run the big heads, and a custom cam. If you're set of the TFS cam, run the 170s, but the really limits your room to grow in the future.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old May 8th, 2011, 11:05 PM   #32
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
lawl, pretty much the same shit I got, except I have a victor intake, and im going to be spraying a 150 shot, 200 if I need too...................... on hyper pistons too
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old May 8th, 2011, 11:21 PM   #33
1991 Mustang LX 5.0
That's what I have, not saying that it's what you should use... just to keep it straight. The car isn't tuned yet, and I barely had it going last year before the snow flew, but I was happy with the results. I am only using the cam because it isn't/wasn't my final combo, so I wanted to use something that I knew would work. Power left on table, sure, but I didn't want to go custom because I was going to be changing so much up on the car. I also wouldn't use a track heat intake if my nitrous plate wasn't already for the street/track intakes. But I'm to cheap to buy a new plate and intake for this motor.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/217182-tw-170-afr-165-stock-bottom-end-w-tfs-stage-2-cam.html
Thread TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam | Forums at Modded Mustangs | BoardReader This thread Refback December 15th, 2011 08:50 PM
Threads Similar to: TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam
Max HP on a stock 3V bottom end? 06PONY 2005 - 2010 24 May 9th, 2011 03:11 PM
maximum rpm for stock bottom end predator421 5.0 Mustangs 12 June 7th, 2010 06:00 PM
How Much HP On Stock Bottom End 5litercobra 2.3 Mustangs 5 November 13th, 2007 02:55 PM
12s with stock bottom end? 95wip 94-95 8 April 16th, 2007 11:10 PM
How Much HP Can Stock GT Bottom End Take? Clutchmaster 99-04 14 March 22nd, 2007 03:58 PM
