LinkBack (1) | Thread Tools |
#1
90 GT
TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam
<see title>
Don't want any PTV clearance issues. Already have a Street Heat Intake. Thanks...
Rewarding our friends, punishing our enemies. |
93 5.0 lx
both are good heads, I would go TW 170 just my opinion
'89 LX 'Vert
10's or bust... Literally.
pretty sure the AFR's are inline heads, and therefor wont let the trickflow stage 2 cam clear.
plus afr 165 heads flow like shit. whats with everyone going for this cam all a sudden? When I got mine no one had em.
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
90 GT
Well the cam came at a good price.
I'm concerned about the clearance. Since I already have a TF intake & cam, I think I'll go with the TF 170 heads. My next question is whats the differences between the 2,3,4,5,etc at the end of the part number? TFS-5140000x Thanks...
1969 Mustang Mach 1
6.824@101.61
TW170s without a doubt. The AFR 165s won't give any clearance issues either, because they have small valves, unlike the TWs 2.02/1.60 valves. The TWs shouldn't give you any troubles with that cam, and are leaps and bounds better than the AFR 165. The TW170 is better compared to an AFR 185.
It's still a very good idea to check P to V clearance, regardless of which head you are using.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
90 GT
Right on. I've been leaning towards the Trickflow heads. Now, the flip side is I've heard that the AFR's are ported/polished out of the box (I've heard, don't know personally) whereas the Trickflows could use additional work to get them to their best potential.
I appreciate your responses. I'm about to drop the cash on these next week at the Summit store when I'm up in Reno on Tuesday. Thanks...
#7 | |
1991 Ford Mustang GT
#8 | |
1969 Mustang Mach 1
6.824@101.61
I could be totally wrong about this, but I think AFR claims more CFMs in their 185, than TFS claims in the TW185, but the TW does considerably better in the mid lift range, where you spend most your time. On a big bore block, the AFR is every bit as good, if not better than the TW because it doesn't suffer from the intake valve being shrouded like it does on the stock blocks. Stock blocks are where the TWs shine.
1992 Lx
11.39@119.24
afr 165s are like full of ridges where they were made, shit is stupid
#10 | |
90 GT
So TW170s are the ones I'm going to get. Thanks for everyones responses!
#12 | |
89 GT
The fact that the AFR's are CNC ported from the factory doesn't really mean much. Yea the port walls are clean of casting flash, but the general shape of the TW port and valve placement is superior over the AFR port on a stock bore engine, and port design is a lot more important than nice shiny port walls. |
90 GT
Another question... I have an old timer friend who's putting a bug in my ear saying aluminum heads warp and to be careful. He used the cadillac 4100 motor in particular saying that you always had to use the liquid additive in the coolant to get it to seal properly.
Are those problems a thing of the past? Thanks...
89 GT
Yea, don't listen to the old timers. They like to live in the past. My aluminum heads have been overheated plenty of times and have never needed to be milled to get them true. There's tons of cars that use aluminum heads. I'm sure that caddy motor was just one of GM's fuck-ups somewhere. LSx engines are entirely aluminum from the factory, block and heads.
1969 Mustang Mach 1
6.824@101.61
No worries....a lot of old timers say that, and it's totally false. All production cars have aluminum heads now days, and a lot have aluminum heads, and an iron block. I have ran a lot of aluminum heads, and have yet to see one warp.
1969 Mustang Mach 1
6.824@101.61
I got tree'd!
90 GT
Thanks...
I appreciate all of your responses in helping me make my decision!
89 GT
1991 Mustang LX 5.0
From what I always read from the benchflow people on here is that the AFR 185's outflow the mid range, but the tf170's had more cfm in the higher lift. Or was it vice versa? Either way, both are comparable heads with one being an inline. As far as the CNC'ing on the AFR's, it's available in two versions. One more rough, and one more smooth, from what I remember from back in the day.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
[IMG]
[/IMG]
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/217182-tw-170-afr-165-stock-bottom-end-w-tfs-stage-2-cam.html
| Thread TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam | Forums at Modded Mustangs | BoardReader | This thread | Refback | December 15th, 2011 08:50 PM | |
Threads Similar to: TW 170 or AFR 165 on Stock Bottom End w/ TFS Stage 2 Cam
| Max HP on a stock 3V bottom end? | 06PONY | 2005 - 2010 | 24 | May 9th, 2011 03:11 PM |
| maximum rpm for stock bottom end | predator421 | 5.0 Mustangs | 12 | June 7th, 2010 06:00 PM |
| How Much HP On Stock Bottom End | 5litercobra | 2.3 Mustangs | 5 | November 13th, 2007 02:55 PM |
| 12s with stock bottom end? | 95wip | 94-95 | 8 | April 16th, 2007 11:10 PM |
| How Much HP Can Stock GT Bottom End Take? | Clutchmaster | 99-04 | 14 | March 22nd, 2007 03:58 PM |
