When should you upgrade stock ignition?
Here is my setup:
5.0 HO out of a 91 Mild Lunati Cam (similar specs to Ford E cam) Ported and Polished GT40p heads and intake Paxton Novi setup for 10-12psi 70mm throttle body 42lb injectors 90mm mass airflow 255lph fuel pump and inline pump Fuel Pressure Regulator MSD Blaster Coil MAC shorty headers BBK Hi-Flow Cat H-Pipe Magnaflow CatBack MAC Underdrive Pulleys I would like add a boost timing master. Should I get the MSD unit designed for the stock ford ignition, the 6btm or a 6al and 8762 btm unit? Thanks
Current Mustangs: 2004 Cobra Convertible 1993 5.0 LX Hatchback 1992 5.0 LX Convertible |
6al is the best unit availeble in my opinion. Def. get that one. I run that one myself.
A 6al should be plenty good for a street car.
dont change your distributor..there is money better spent elswhere...but get a 6AL it has a built in rev limitor unlike the 6A
and also its general that anything running over 10:1 compression you should upgrade
Threads Similar to: When should you upgrade stock ignition?
| Mustang Stock needed upgrade | DeSMustang | 5.0 Mustangs | 14 | May 14th, 2007 09:36 PM |
| Ignition system upgrade | Dj1123 | V6 Mustangs | 1 | May 14th, 2007 11:33 AM |
| Stock ignition key | impetus | 2005 - 2010 | 17 | April 20th, 2007 03:33 PM |
| msd ignition on 98 gt | burlingtonNC98GT | 96-98 | 5 | January 3rd, 2007 01:28 AM |
| Stock 06 Mustang GT, Looking For Help On What To Buy/Upgrade | FireryDriver | 2005 - 2010 | 9 | September 14th, 2006 02:09 PM |
