Displacement Chart
Old May 6th, 2007, 01:08 PM   #1
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Displacement Chart
I got bored one day and took a calculator and calculated out the possible displacements of the 302w and the 351w. I figured some of you guys might find the chart helpful so i went ahead and typed it up. Hope this helps a few of you out there.
Old May 6th, 2007, 04:24 PM   #2
zero is on a distinguished road
Send a message via AIM to zero
thats pretty sweet. mustve been bored as hell man. what size did you put in for the combustion chamber and head gasket thickness though?
92 lx
351W w/ 60 overbore
holley 600cfm carb
weiand stealth dual plane intake
240/246@.510 cam
bbk long tube headders
msd coil
5 lug axle conversion
3.55 gears
mach1 style 17" rims
Old May 7th, 2007, 11:06 AM   #3
combustion chamber and head gasket thickness arent included in the ratio. For those you have to compensate. No matter what head gasket or cylinder heads you have, the displacement should be the same. The formual is as follows: (pi/4)(bore)(bore)(stroke)(number of pistons)
Old May 7th, 2007, 11:23 AM   #4
TurboLX's Avatar
1988 Mustang LX Turbo
nice find
Old May 8th, 2007, 11:02 AM   #5
Can an admin or mod make this a sticky.. :wink
also, gasket thickness and Head chamber size affect compression ratio. The bore and stroke have a effect on the compression ratio as well. Generally, as stroke increases compression ratio increases as well. As bore increases, the compression ratio drops slightly, pending on how much the bore increases.
Threads Similar to: Displacement Chart
HP And 1/4 Mile Estimates Chart! JONJON 5.0 Mustangs 13 November 19th, 2007 04:02 PM
questions about red circle pie chart magnet... Casper98GT The Clubhouse 15 September 22nd, 2007 03:08 PM
New 4.10's... and conversion chart! wormster00 2005 - 2010 15 June 28th, 2007 12:40 AM
ENGINE DISPLACEMENT ?'S 94' Cobra 351 General Tech 3 January 30th, 2007 05:10 PM
engine displacement skryb V6 Mustangs 2 September 3rd, 2006 11:13 AM
