3 1/2 inch x pipe and mufler
I have a stock '86 GT. A local guy is selling a 3 1/2" x pipe with the two flowmasters for a great price. I was considering installing behind my stock headers and back into the stock tail pips. I think the tail pipes a 2 1/4 but not sure. What are your guys opinions? and what cam should I get to go with the new pipes?
1991 Mustang LX 5.0
Waste of time to have that big of exhaust only in the middle of the exhaust system with what I'm guessing is a relatively stock motor. And you don't buy cams to go with exhaust, you buy cams to go with motor combinations.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#3 | |
1991 Ford Mustang GT
stock car you'll go slower with that setup
1989 LX hatch
15 and change
save your $$ and get a good 2 1/2 full exhaust.
1987 Buick Grand National 1989 Mustang LX 5.0 Both BLACK
1995 Mustang GT
yeah 3 1/2 is a bit overkill lol, ur gonna lose back pressure and hp with a stock car...
![]() "my wheel bolts require more torque than your honda makes"
89 GT
Backpressure is a myth. It does nothing for your car.
You actually do want to match your cam to the exhaust. But it's the collector of the header, not the x pipe or anything else. A cam matched to a collector will maximize scavenging in it's application. |
#8 | |
#9 | |||
![]() ![]() I am having a hard time believing that. Maybe off the line, but it would open up the upper RPM performance. So your saying if I ran open headers it would hurt performance? hmmm even if I changed to the proper cam shaft? ![]() Even if its feeding back into the tail pipes that are 2 1/4. I don't see anything wrong with over kill, as long as it don't hurt performance.The guy is selling the 3 1/2 in pipes from header to x pipe to two flow master 3 1/2 mufflers all for $150. the back of the mufflers have turn downs but I was considering plumbing them back into my tailpipes to add a little back presure. I can weld and install the pipes myself. I'm not to sure about that. I mean backpresure does help with torque. At least on my Jeep motor it did. I always thought with open headers you wanted a specific cam shaft. |
89 GT
1991 Mustang LX 5.0
If you look at backpressure as a restriction, yes, it can have it's place depending on the motor setup. There must be a certain amount of resistance to create the scavanging effect. A stock motor with 1 7/8 primaries and full 3 1/2 inch exhaust will not perform as well under all circumstances as the same motor with 2 1/2 inch exhaust. But with the right combo, backpressure is a killer. My 900rr's exhaust is a 4 into 2 into 1 flowing through a straight though muffler. No backpressure there other than the size of the pipes and length of the tubes in the 2 into one section. That's how it can do 13,000 rpms, but off idle (1100rpm) to 3k, it's a turd. It's what the cam was designed for.
1992 Lx
11.39@119.24
my car picked up 3mph pullin mufflers and runnin skinnys
do the math
1991 Mustang LX 5.0
That's why I said under all circumstances... if that was directed at me.
1992 Lx
11.39@119.24
na wasnt specifically just my personal experience as a pro race car driver
1991 Mustang LX 5.0
and pro engine builder, lol
Threads Similar to: 3 1/2 inch x pipe and mufler
| mufler help! | wxexs92 | 5.0 Mustangs | 7 | April 27th, 2011 01:18 PM |
| mufler | stfudvs | 5.0 Mustangs | 6 | March 31st, 2009 05:14 AM |
| 3 inch vs 2 1/2 inch exhasut ? | Black Bullitt | 99-04 | 15 | September 13th, 2008 12:21 PM |
| 67 mustang 8 inch or 9 inch? | My67_fastback | Classic Mustangs | 15 | June 25th, 2008 08:29 AM |
