Random missing
Old May 6th, 2007, 03:52 PM   #1
nolife's Avatar
91GT, 88GT, 02GT
Random missing
I have an issue with what I believe is some random missing. It is not happening all the time and when it does it, it's not really bad until high rpm under load (at about 5000+ it will sputter). I can get on it hard in 1st and it starts to sputter, shift to second and the miss is gone and it pulls nicely to 6200+. I've recenty replaced the plugs, wires, cap and rotor and I've replaced the cap, rotor and wires again but that did not help. I guess my next step will be to swap out the coil with my other Mustang and temporarily remove my boost retard module but after that, I am out of ideas. TFI module maybe? I think I've noticed the tach jumping around a little when it is actively missing but it may have done that before this problem started. I do not hear any detonation (and with the Vortech and the exhaust, I don't know that I would hear it anyway).
Could this be a fuel injector issue or should I stick to troubleshooting the spark?
Old May 6th, 2007, 04:20 PM   #2
zero is on a distinguished road
Send a message via AIM to zero
i would look at your injectors. if its only doing it at high rpms under load, thats not conducive to loss of spark. im hesitant to say though that its not an advance problem in your timing. id check up on your advance timing at higher rpms. but what do i know, my cars having spark/fuel issues at the moment.
92 lx
351W w/ 60 overbore
holley 600cfm carb
weiand stealth dual plane intake
240/246@.510 cam
bbk long tube headders
msd coil
5 lug axle conversion
3.55 gears
mach1 style 17" rims
Old May 6th, 2007, 06:28 PM   #3
IcantDo55 is on a distinguished road
Remove the BTM. They are notorious with that problem.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old May 6th, 2007, 06:32 PM   #4
btm?
92 lx
351W w/ 60 overbore
holley 600cfm carb
240/246@.510 cam
msd coil
3.55 gears
Old May 6th, 2007, 06:53 PM   #5
BTM = boost retard module
MSD calls it a Boost timing module
-Mike
Link to My Site
Stroked and Blown!
Old May 6th, 2007, 06:54 PM   #6
looks like greek to me. ive got a distributor with a vaccum and mechanical advance.
92 lx
351W w/ 60 overbore
holley 600cfm carb
240/246@.510 cam
msd coil
3.55 gears
Old May 6th, 2007, 06:59 PM   #7
Re: Random missing
Just saw that in your post and thought you had one. Sorry.
PS: mosy TFI work or don't.
-Mike
Link to My Site
Stroked and Blown!
Old May 6th, 2007, 07:03 PM   #8
gotcha. yeah ive given up working on fi or tfi. life is so much easier with a carb.
92 lx
351W w/ 60 overbore
holley 600cfm carb
240/246@.510 cam
msd coil
3.55 gears
Old May 6th, 2007, 07:55 PM   #9
nolife's Avatar
91GT, 88GT, 02GT
Re: Random missing
I do have a boost retard and I will check that. I was not the one that replied to you yet
I have not messed with the ignition on this car since I bought it so don't know exactly what it has for a chip or spark. I can go beyond 6200 which the factory rev limit so i know it a least has a chip. It may be time to at least find out what I have in there computer wise.
It does miss at all RPM and even idle when it is acting up but it is barely noticable until I am under load and at high rpm. If I am driving at a constant 2K in 5th gear, about once every 1 to 10 seconds, I can here a mis but it does not affect the drivability. When under boost and passing 6000 RPM, those one or two misfires make a big difference.
Threads Similar to: Random missing
97 V6 missing on cyl 4,5,and 6 a_calm_victim V6 Mustangs 10 July 5th, 2007 08:48 AM
My Intake Was Missing Something vnmous Pictures 8 June 25th, 2007 05:20 PM
missing something and need a hand extropy Classic Mustangs 4 May 19th, 2007 10:50 PM
Car Missing Out Bad bigbadtalontsi 5.0 Mustangs 7 March 28th, 2007 06:14 AM
Car Missing Out bigbadtalontsi 5.0 Mustangs 10 March 11th, 2007 05:47 PM
