Will a small rear main leak cause a chirpy throwout bearing
Old May 8th, 2011, 02:51 PM   #1
87superduperstang is on a distinguished road
I noticed i have a small leak in the rear main seal and noticed that once in a while my throwout bearing is squicking. The only time the throwout bearing seems to squick is if im parked on an incline which caused my to believe when its parked like that little oil my be getting on it. Reason i think it is my throwout bearing is it stops when i barely push the clutch pedal . the 6 spd trans, aluminum flywheel , clutch and everything that goes with the clucch is new only like 2000 miles max. Is this something i should be worried about. and i believe it my be a stock 03-04 cobra clutch unsure ??
Old May 8th, 2011, 07:10 PM   #2
nxcoupe is on a distinguished road
squeak? A rear main seal leak does not affect your throw out bearing. What year is your car?
90 GT 393 5 spd, 467 rwhp 480 rwtq
92 coupe, R/S 308 5 spd
93 coupe, 2.3 5 spd
Threads Similar to: Will a small rear main leak cause a chirpy throwout bearing
Rear main seal leak will i pass tech inspection?? black88 5.0 Mustangs 4 May 4th, 2011 04:32 PM
Possible Rear Main Seal Leak??? wrr1020 99-04 4 April 4th, 2011 09:16 PM
Throwout bearing again.... RedDevilGT V6 Mustangs 7 April 6th, 2009 07:31 PM
rear main leak kreil45 5.0 Mustangs 5 April 13th, 2007 10:16 AM
Rear main leak troy1000rr 94-95 1 December 31st, 2006 11:43 AM
