GT40 LS2/LS6 springs
dropping my heads off at the machine shop tomorrow then ordering the LS2/LS6 valve springs comp retainers and locks, fel pro seals. havent seen much info on this but from what i have it seems cheap and a lot better. 570 lift capable and lighter supposidly. thought it was interesting, figured id try it. any input would be helpful.
springs 67.95 retainers 49.95 locks 22.25 ill update on machine work cost, progress and anything else i run into |
2003 mustang
7.48x1.56=11.67
I'm running the 02+ oem ls6 springs on my engine for about 1 1/2yr. .540/.541 216/222@500.
I wouldnt go over .550 with those springs. Where you buying from? btw...I'm running them on a 3.8 v6
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
summit, they say they are rated at .570 and a f cam w 1.72s is like .550.4 so i should be fine... i hope
2003 mustang
7.48x1.56=11.67
26915 or 26918 comp springs? The ones i got are from legenfelter and are oem takeoffs from an 02+ ls6.
Didnt know summit carried them as well. I'm doing the comp 26915's and going with a bigger cam myself....somewhere around .580 230/240 @.500 114*
1969 Mustang Mach 1
6.824@101.61
Springs are never good to X amount of lift. What's crazy is if you call a manufacturer like TFS that makes cams, and heads, and sell heads with springs, they will tell you the same thing. Always, always, always, call the cam manufacturer and ask them if the springs are acceptable for the cam.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
NAL-12499224 those are the springs. and yea this is more of a budget build with spare parts for now im just saying what they are "said" to handle. either way it will work or it wont only one sure way to find out.
#7 | |
Proud American
Threads Similar to: GT40 LS2/LS6 springs
| gt40 intake/gt40 heads | black05gt | 5.0 Mustangs | 13 | March 10th, 2011 10:47 PM |
| gt40 cam selection and springs | fordguy1280 | 5.0 Mustangs | 30 | October 3rd, 2010 10:48 PM |
| H&R SuperSport Springs or Steeda Ultralite Springs | CaptDeanSierra | 2005 - 2010 V6 | 4 | September 5th, 2010 12:07 PM |
| Summit springs Vs Ford C springs. Advice? | SlowNorth | 99-04 | 4 | May 3rd, 2010 01:44 PM |
| stock springs vs lowering springs in drag | TotoGT06 | 2005 - 2010 | 4 | April 14th, 2010 10:25 PM |
