Idiot of the year award goes to.......me! - Page 3
Old May 11th, 2011, 10:35 PM   #41
ggreene is on a distinguished road
I talked to two reputable engine builder around here, the ysaid if I took the motor back out and brought them the short block it would be 1500-2000 to take apart, balance and put back together. He said since I started it he would nto put it back together without all new rings, rod and main bearings. That just seems nuts to me. Would It be worth my while to put a 28oz balancer and flywheel and give it a shot? It is a street motor, not going to be turning high RPMS. I really dont want to sink another 1500 in this thing, unless I really need to. Would much rather spend the 1500 on a better set of heads and cam.
Old May 11th, 2011, 10:40 PM   #42
Wow! A couple hundred bucks now? It seems like the last one I built myself was $75. I obviously didn't worry about it on this engine
I thought it was a simple question also. I asked "what balancer should I put on it" he just kept saying it would be easier to balance with a 28 then it would a 50. I having this thing all the way together and running, really going to set me back time and money if I have to take it all back out and have the short block rebuilt. But if that is what I have to do then I guess thats all part of learning, huh? Now I wish I would have asked more questions about balancing than I did about my shitty h/c/i when I was putting together...lol
Old May 11th, 2011, 10:44 PM   #43
1992 Lx
11.39@119.24
worst shop evar
Old May 11th, 2011, 10:53 PM   #44
Originally Posted by 93hatch View Post
worst shop evar
That price seemed crazy to me, it was late in the day before I had the chance to call around much. I just talked to two different guys that was reconmended to me. I will do some more calling around tomorow. WHat balancer and flywheel would you all recomend? What about a summit balancer? Hawks flywheel from TMD?(even though they are dodging my question). Thats the best prices I have found but dont want to get total junk.
Old May 11th, 2011, 10:59 PM   #45
1992 Lx
11.39@119.24
you will find somethin in a few days here The Corral
Old May 12th, 2011, 02:03 AM   #46
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Originally Posted by fogged306 View Post
Damn, $75 to have the whole assembly balanced? ... maybe I should shop around? I've been using the same guy for years now and it's always been $175 IIRC... how long ago did you build that last engine you old fuck?
My local shops prices for a single engine customer
degrease block - $42.00
check align bore - $42.00
hone block - $58.00 or
bore & hone - $126.00
clean & polish crank - $38.00 or
clean & grind crank - $126.00
shotpeen crank (optional) $31.00
balance crank (need weight of rod & piston, & need balancer & flywheel) - $126.00
valve job (302 heads) $370/pair - this is an estimate - not sure what parts are needed in your heads
JBs Auto and machine
Philidelphia Rd White Marsh Md
I use them a lot to do engine work for me so there 20% cheaper for me.
Threads Similar to: Idiot of the year award goes to.......me!
Driver of the year award(nascar drift) itschristorres8 The Clubhouse 25 November 26th, 2009 01:47 PM
and the award.. Squints The Clubhouse 4 March 7th, 2009 04:26 PM
Engine of the year award Regency 2007 The Clubhouse 12 September 4th, 2008 10:47 PM
Dumb Dumb Question on my part. mustangmanic The Clubhouse 53 July 3rd, 2008 12:57 AM
