91 Mustang LX 5.0
Car won't start after T-5 swap
So got done with the t5 swap and the car won't start afterwards. i think it has something to do with the harness that plugs into the trans. it will turn over but wont fire and it sounds like the starters not getting enough power to it and my batterys charged so i dont know what else it could be
any advice would help |
Billy Weston
Well start with the basics and see if you are getting power to the solenoid when trying to crank the motor over.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
91 Mustang LX 5.0
I dunno what the hell is goin on... I just started it by jumping it and then it wouldn't start after I took the cables off... it still sounds like thrers barely any power to the starter
1992 Lx
11.39@119.24
you using a t5 harness or you just bypass the neutral safety switch from the auto one?
Billy Weston
Sounds like power and ground issues.... make sure your battery terminals are CLEAN and tight. then start poking around your grounds. A good way to find out if you have a ground issue is to take your jumper cables and attach a lead to your block and the other end to the negative battery terminal. If it fires off then you know it isn't getting a good ground.
91 Mustang LX 5.0
And nothing happens when I cross the terminals on the solenoid
Billy Weston
See above post.
Billy Weston
Are you sure it's not just a dead battery?
1990 mustang gt
get a meter and test your battery, and check the voltage while cranking
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
91 Mustang LX 5.0
Alright hooked up a volt meter to the solenoid and nothing when I try to start it. And that batterys fine I just checked that
Billy Weston
scratch that you said it would start when jumping the battery?
check the grounds yet?
1990 mustang gt
did you check on the battery post, and then the battery terminal to see if you get 12v. make sure you have a good ground on the meter also if not it doesnt work
91 Mustang LX 5.0
checked the battery post when trying to crank and it dropped a little and then checked the solenoid when cranking and it went to zero
and yes i got it to start by jumping it |
91 Mustang LX 5.0
and checked the grounds with a jumper cable from the battery post to the block and also tried to the trans
Billy Weston
How about chassis to the battery?
91 Mustang LX 5.0
Nothing with battery to chassis
1990 mustang gt
Then its either the wire from battery to solenoid or the terminal on that wire
91 Mustang LX 5.0
That would make since of it was the terminal and explain why I could start it when I jumped it
91 Mustang LX 5.0
Wtf?!?! Still nothing just crankin over.
What else could it be??? |
91 Mustang LX 5.0
I finally found it.
there was a short in a wire running to the coil |
Threads Similar to: Car won't start after T-5 swap
| pi swap start. help. | V8POWA! | 96-98 | 0 | January 2nd, 2011 09:36 PM |
| 4v swap START UP VIDEO! | Stephen4036 | Videos | 21 | April 25th, 2010 04:48 PM |
| car wont start after tranny swap | whitestrk2 | 5.0 Mustangs | 9 | March 21st, 2010 01:12 PM |
| 4.2 swap, engine wont start | 99v6stang | V6 Mustangs | 47 | October 11th, 2007 07:49 PM |
| engine swap, car won't start horn dead | OTreborO | 5.0 Mustangs | 9 | July 27th, 2006 05:39 PM |
