squeaky suspension
Old May 10th, 2011, 11:11 PM   #1
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
brimmer555 is on a distinguished road
squeaky suspension
any one know what makes so many mustangs like my 89 gt's suspention squeek so bad?
it's driving my nutz bumps an just driving around makes it squeek.
89 GT RESTO-MOD
http://www.youtube.com/watch?v=OWjkD...feature=colike
Old May 10th, 2011, 11:19 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
rotted dried up bushings
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 11th, 2011, 12:04 AM   #3
kmedeiros88's Avatar
89 Mustang LX Hatch
kmedeiros88 is on a distinguished road
Def some shitty bushings. Replace them with urethane ones, they last longer. Also, check the ball joints, even though they sound more like a clunk than a squeak.
Old May 11th, 2011, 12:22 AM   #4
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
where should i start with the bushings?
89 GT RESTO-MOD
Old May 11th, 2011, 12:38 AM   #5
jkeyz's Avatar
93 5.0 lx
jkeyz is on a distinguished road
i believe i saw a kit on summit or jegs, idk just google it they sell a polyurethane bushing kit for our cars. And make sure you install them correctly or else they will squeek lol
Heres an idea.. ban the ones that are most knowlegable and helpful in the 5.0 section...oh wait lmao
Old May 11th, 2011, 12:41 AM   #6
ryanw's Avatar
front sway bar bushings and sway bar end links w/bushings
255 fuel pump,
3:27 gears
Old May 11th, 2011, 03:01 PM   #7
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
Iused to have a prothane bushings kit but i traded it up for my BBK ceramic coated headers, because I needed them to be able to drive my car lol.
ok cool, i'll get the bushings for the sway bars first then. Thanks
89 GT RESTO-MOD
Old May 11th, 2011, 05:46 PM   #8
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
ball joints squeak like hell when there shot and not greased
Old May 11th, 2011, 10:22 PM   #9
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
This is gonna sound dumb but where are these ball joints?
only think I can think of is tie-rod ends, that have any kinda ball to them.
I also noticed that when I had it at the shop after I bought it, they had done something that made it not squeek for a few days.
89 GT RESTO-MOD
Old May 12th, 2011, 12:27 AM   #10
89 Mustang LX Hatch
Ball joints are the pivot points on the control arms. Look for rubber boots, make sure there is some grease in there.
Old May 12th, 2011, 12:29 AM   #11
89 Mustang LX Hatch
I would check all the rubber boots and bushings under the car just to be safe. you can easily tell when one is bad by looking at them.
Old May 12th, 2011, 01:12 AM   #12
That is a ball joint and will be pressed into your lower control arm... most likely it needs to be greased or replaced but I'd try to pin point where this noise is coming from first before you throw money at the car.
Old May 12th, 2011, 11:28 AM   #13
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
Trust me I would much rather find the squeeker than through money at the issue.
aspecialy since I have a little one on the way.
89 GT RESTO-MOD
Old May 12th, 2011, 02:57 PM   #14
Get someone to help you narrow down where the noise is coming from then poke around that area and find the issue. I mean im sure the car could stand to have all the bushings replaced through out the thing but like you said you have a kid on the way so I wouldn't f with someting that's not broken or causing a problem yet.
I have tubular a arms on both my cars so I can't remember off hand 100% but im pretty sure the stock a arms have ball joints pressed into them and aren't serviceable which means new arms/ball joints but aagain it's been a while since i've had a stock suspen car so i could be wrong but if that is the case then look to spend $300 for them
Old May 12th, 2011, 04:12 PM   #15
Smirnoff's Avatar
1982 GT t-top
you can rent a press to get the ball joints out and back in its basically a c clamp with some adapters to fit over one side and on the other depending on which way youre pushing the ball joint through, the ball joints are cheap anyway i spent 11 bucks a piece on mine. Does it make noise when you hit bumps mainly or does it do it while turning more?
Old May 12th, 2011, 05:52 PM   #16
91cobra5.0's Avatar
98 Cobra
Crawl under the car while all 4 tires are on a level serface with the cars full weight on the suspension, brake the nuts and bolts loose that connect any suspension part to the chasis (u&l control arms + a arms) then re tighten and it wouldn't hurt to rub on a little grease around the bolt onto the bushing if they are old and dried up
Old May 12th, 2011, 07:26 PM   #17
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
It's mostly with bumps.
89 GT RESTO-MOD
Old May 13th, 2011, 01:01 AM   #18
Smirnoff's Avatar
1982 GT t-top
then id aim towards the ball joints thats what mine did on my car and my truck
Old May 13th, 2011, 12:34 PM   #19
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
have the same problem from time to time. I just WD40'd it and its gone. I will be changing them all soon.
Old May 13th, 2011, 03:32 PM   #20
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
I was wrong some of the squeek was coming from the steering also. I'm sure the bushings on the power steering rack are shot. because I have alot of slop in my steering. and when i'm on the highway it gets really loose.
I shot some PB blast on the bushings in the lower A-arm and the end links of the front swaybar, and for the most part the squeeking was gone, but that was short lived.
89 GT RESTO-MOD
Threads Similar to: squeaky suspension
Squeaky Tranny Gerbig 2005 - 2010 V6 0 May 6th, 2011 04:24 PM
Squeaky front end... RAGEman 99-04 9 June 4th, 2010 11:02 PM
Squeaky Front End Paulnhbtx 99-04 26 March 4th, 2009 10:00 PM
Squeaky... whtpny 99-04 14 November 12th, 2007 12:27 AM
Squeaky crazyjones V6 Mustangs 1 November 3rd, 2007 12:35 AM
