1991 Ford Mustang GT
Heads/Cam idle question
Will a higher lift/duration cam always result in a rougher idle or will it depend on how well the heads flow?
This is probably a horrible example, but would a TFS stage 2 cam result in a rougher idle with AFR 165's vs. higher flowing 185's or would the idle be the same despite the flow of the heads? The reason I ask is because a guy I work with wants to run a set of GT40p heads with a higher lift cam, not necessairly a TFS 2 cam. He is aware he can get a set of TFS springs to run a higher lift, but supposing he upgrades later to aluminum heads which flow better will it result in a smoother idle or would he still keep the lopey idle he is aiming for now? Also will he need any fuel mods with the gt40p heads and will the cam he chooses dictate his ignition timing? |
Canary yellow 1990 GT
Praying for 11's after winter mods
Should keep the lopey idle.
-Edelbrock Performer Intake/Heads -TFS2 Cam -Tremec 3550 -All them other bolt on performance thingys |
with gt40p's and a cam and intake to match id probly go ahead and step up to 24 lb injectors
1992 Lx
11.39@119.24
bigger heads=overall louder car. My afr headed car with a mac catback sounded like dogshit, didnt sound too bad when the car was stock
Threads Similar to: Heads/Cam idle question
| idle question | bkatrenak84 | 5.0 Mustangs | 2 | December 20th, 2010 05:01 PM |
| Cam Question for New Livernois heads ( anyone running these heads? ) | aluv4speed | 99-04 | 12 | July 22nd, 2010 03:10 PM |
| Idle vid of new heads. | jivepepper | Videos | 10 | July 8th, 2008 09:06 PM |
| idle question | 00vabchgt | 99-04 | 7 | May 10th, 2007 02:03 PM |
| Idle question? | dmachine22 | 99-04 | 4 | April 14th, 2007 11:12 PM |
