cam and intake
Old May 12th, 2011, 03:38 PM   #1
90 notch is on a distinguished road
Thumbs down
cam and intake
so I'm looking at gt40 intake and an e303 cam. What's everyones opinion? Heres my specs. 90 5.0 153k miles. Cold air intake, underdrive pulleys, 75mm throttle body and aftermarket headers. I'll eventually get gt40 heads but is this a safe cam for the intake and mostly stock engine?
Old May 12th, 2011, 04:34 PM   #2
1991 Ford Mustang GT
Stdyhand is on a distinguished road
For the money you'll spend on the lettered cam you could probably get a set of GT40 heads, unless your referring to the aluminum gt40's. I would think they would get you more power than that E cam anyhow.
Why do you want the e cam? Have you considered the TFS stage 1 cam? Seems like it would be a better cam but its up to you.
Old May 12th, 2011, 04:50 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I would put anything other than a letter cam in it.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old May 12th, 2011, 05:47 PM   #4
91cobra5.0's Avatar
98 Cobra
I put the same exact combo in my 91 and I was happy with it but it left me wanting for more, my advise is to not use the e cam and get a tfs1 cam, they are the same price and the tfs1 cam will out perform the e cam now and in the long run.
Get everything used check around in the classifieds at corral.net you can have that whole combo for about 500-600$
Old May 12th, 2011, 07:12 PM   #5
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I have a stage 1 for 130 to your door if you're interested
Old May 13th, 2011, 10:09 AM   #6
gt40 stock heads not aluminum I can find cheap. Gt40 intake to match is easy to find. And the e303 I've heard alot of people using and happy with it. I jus thought it sounded like an awesome setup. Should I ugrade injectors?
Old May 13th, 2011, 10:17 AM   #7
1991 Mustang LX 5.0
Had E303 once... I wouldn't unless you live in CA or something. Even then, I still wouldn't. Injectors upgrade on gt40's isn't necessary unless they are seriously hogged out and you are turning some serious R's which you prolly wouldn't be.
Old May 13th, 2011, 10:24 AM   #8
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Seriously man, letter cams suck. The TFS1 cam is a much better cam.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old May 13th, 2011, 02:15 PM   #9
95StangMX's Avatar
95 Mustang GT
Replace the heads first then deal with the cam and intake, the cam is the last thing that needs to be replaced, unless you are just doing it for the sound which is Just pull a plug wire or 2 and you will get your rough idle and save yourself the money and work...
Añd also like mentioned by the others, don"t run an alpahabet cam, it is old outdated technology, the tfs will be a lot better and homie has one he will sell for 130 bucks shipped, thats a deal.... Will you ship it to me for that price? I don"t need it but for 130 to my door I will buy it to resell...haha
Old May 13th, 2011, 08:04 PM   #10
ryanw's Avatar
AND SURVEY SAID ????? TFS1 for the win....the consensus has been confirmed...and opportunity is knocking...130 bucks shipped, thats a great deal
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 13th, 2011, 11:03 PM   #11
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
If you don't get that cam then I'm going to jump on it
Old May 14th, 2011, 07:32 AM   #12
fogged306's Avatar
89 GT
A suppository is about all a letter cam is good for anyway.
Old May 14th, 2011, 11:54 AM   #13
1991 Mustang LX 5.0
Lmao... Not to your door. I need to add a disclaimer about 48 continental united states. First come, first serve on the cam. First with the money wins. Just pm me.
Threads Similar to: cam and intake
Victor jr carbureted intake witg 4.6 to 5.4 intake plates Skinnywhiteguy223 96-98 2 December 2nd, 2010 03:25 AM
Port non p.i. Intake runners to match p.i. Intake racer1997 96-98 11 July 19th, 2009 11:42 PM
non-pi intake to PI intake alum. crossover question ndfrspd 96-98 2 May 29th, 2009 05:47 PM
