fox gauge issues
Old May 13th, 2011, 02:21 AM   #1
1991 Mustang 5.0 lx AOD
teehanrh is on a distinguished road
fox gauge issues
I've been doing some research trying to find information on stock gauge issues. Fox's seem to have a lot of stock gauge problems, but I can't really find any information on something that's a little more specific to my case. I would appreciate some advice before I waste time and money chasing something when I don't really know what I'm doing.
My speedometer is not accurate in the least. I pretty much just bounces around as it pleases, with the only pattern that it increases/decreases it's range with the speed of the car. In addition, the fuel gauge is stuck on empty. I figured it wouldn't be that big of a deal, but I've run out of gas twice (having trouble guessing the mileage of my first v8.
I have some trouble shooting bouts lined up for now, but none are ideal on crutches. So I kinda want to have a plan for when I finally get back on my own two feet.
Anyone have any past experience or advice on this situation? All answers are greatly appreciated.
'91 5.0 notch
Old May 13th, 2011, 02:41 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
i had the same issues with those same two gauges...
When it come to the fuel gauge it could be: the gauge it self, the wiring to the fuel tank,or the fuel sending unit......But 90-93 mustangs there is also a anti slosh circuit board that plugs into the back of your gauge cluster, this circuit board is also a voltage regulator for your gauges.. In my case my circuit board was bad, it just plugs right in
1990-93 Mustang Instrument Voltage Regulator by Ford at LRS - Same Day Shipping!
As for your speedo....Its either the gauge it self or the speedo cable.
I figured id replace my speedo cable because there cheap, after replacing it, it was still just bouncing around. It turns out my stepper gear or some thing like that was messed up inside, so i just went and bought a used gauge cluster, you can buy just the speedo if you need to, but if you do end up having to replace your complete cluster, you can only use the ones from 90-93, even though they all look the same, they are not.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 13th, 2011, 03:40 AM   #3
Cloud Nine's Avatar
1990 Mustang
Cloud Nine is on a distinguished road
My speedometer gauge didnt move at all and then when I hit 5th or high rpms in 4th the needle would start bouncing up and down. I pulled the speedometer cable and the speedometer gear was eaten up. That might be the problem if the other things ryan suggested arent the reason
Threads Similar to: fox gauge issues
GT500 Fuel Pump Gauge Issues justin503 2005 - 2010 11 April 18th, 2011 07:22 PM
MSD 6AL causing rpm gauge issues WhiteMamba 5.0 Mustangs 0 October 8th, 2010 12:28 AM
msd6al causing rpm gauge issues??? WhiteMamba 5.0 Mustangs 0 September 24th, 2010 05:02 PM
Temp Gauge Issues banks90gt 5.0 Mustangs 7 September 5th, 2010 02:29 AM
fuel gauge issues. 03svtcobra Audio/Video 9 September 30th, 2009 07:11 PM
