sound system set up
Old May 13th, 2011, 07:53 PM   #1
khiyasu is on a distinguished road
sound system set up
hi guys, just wondering if anyone has had any experience testing subwoofer set ups in a 99-04 GT coupe.
i have 2 jl 10w3v3s powered by an alpine pdx m6 digital amp that i want to make a custom box for but cant decide if i want them facing each other, facing the front, or the back.
right now I am looking at 3 options,
1. one similar to the zenclosures box. two subs pressed up against the back seats and firing backwards into the trunk. i like this one because it saves some space and looks neat.
2. getting two separate fiberglass enclosures that will be located in the two corners of the trunk (right by where the tail lights are) and have the subs facing up/the front of the car. this will help save space the best as i can still put down the rear seats and have an even larger trunk space.
3. same as #2 but have the subs facing each other.
my only concern is i want good quality, clean and full bass and I don't want the trunk or car to rattle. also, I would like to save trunk space if possible.
if anyone could help me with their experience, it would be greatly appreciated. thanks!
Old May 14th, 2011, 03:09 AM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
for best sound i would have them firing backwards but up at a slight angle also to bounce it off the hatch
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old May 14th, 2011, 01:05 PM   #3
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
car doesnt have a hatch.
In a trunk...face them backwards with the right size box.
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old May 14th, 2011, 01:16 PM   #4
fogged306's Avatar
89 GT
This is generally your best bet.
You can face them at each other and make it sound good, but it's a bit tougher to do so because you need to have them at the correct distance apart. If you put them in opposite corners, you might get lucky and it will sound good, you might not and it will sound like shit.
If you want clean bass, make sure you do a sealed box and definitely do what digsj7 said, get the right box. No matter how good your sub is, if it's in the wrong box, it will sound like garbage. If the subs are brand new, they should have a sheet telling you what dimensions the box needs to be. Should be 2 different styles of box they list, a sealed and a vented. Vented boxes will be louder and lower, sealed boxes will be tighter and cleaner. JL's always sound amazing in sealed boxes. One of the only subs I like in a sealed box.
If you don't want the trunk to rattle, be prepared to do some work. Dynamat and great stuff are your friends... Just be careful with the great stuff, it expands a lot when it dries. Don't put a lot in a small area and then seal it up with something. I've seen that stuff make a mess of things when people don't know what they're doing with it.
Threads Similar to: sound system set up
Sound system? 08knight 2005 - 2010 V6 3 August 30th, 2010 09:40 PM
Sound System Help... Bryan57 V6 Mustangs 18 January 11th, 2008 10:09 AM
Sound system... D-Brow Audio/Video 26 February 25th, 2007 08:32 PM
Sound System Help Laser Audio/Video 3 January 13th, 2007 02:58 PM
My Sound System trueballerisme 2005 - 2010 30 December 31st, 2006 11:47 AM
