Roller Rocker Questions
Old May 14th, 2011, 01:30 PM   #1
Robert20 is on a distinguished road
Was kicking around the idea of buying a set of rockers for my car. Was wanting a tad bit more lope to my idle, since I plan on getting rid of my 3 chamber Flowmasters for maybe a 2 chamber or a new MAC Prochamber catback. Is it even worth the hassle throwing them on stock E7 heads? I don't really feel like buying a cam, seeing as it really wouldn't help too much with my stock heads. I don't plan on doing much more to my car since it's my clear weather DD and it runs so damn well.
____________________________________
paintless dent removal
Old May 14th, 2011, 01:33 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
if you do get RR you will need pedestal mounted rockers, not stud
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 14th, 2011, 01:57 PM   #3
1992 Lx
11.39@119.24
wont make it lope
Old May 14th, 2011, 02:21 PM   #4
fogged306's Avatar
89 GT
^^ This.. increasing rocker ratio will only increase lift. Duration and overlap is what gives you lope.
Threads Similar to: Roller Rocker Questions
roller rocker ?' Sally845 5.0 Mustangs 8 January 17th, 2011 07:41 PM
Roller Rocker Arm Kit scxc15 V6 Mustangs 24 January 25th, 2008 08:09 AM
roller rocker Info imported_Gt_Jay 5.0 Mustangs 5 November 11th, 2007 03:33 AM
Roller Rocker help sniperrider 5.0 Mustangs 12 August 31st, 2007 10:00 PM
roller rocker ? marcd 5.0 Mustangs 15 June 25th, 2007 10:35 PM
