Victor Jr Heads on this build? Specs inside...
So a local guy is selling his fox, and these are the specs on a fresh engine build. I've always "heard" that the Victor Jr heads flowed too much for a basically stock 302, BUT this car does have a custom Cam in it.
Cam:224/232. Intake lift 542/563 exhaust lift. 112lsa+4 1.7 rocker arms TRW Pistons 10.074 compression ratio (according to build sheet) Trickflow intake 24# injectors Any idea on numbers/times? ____________________________________ paintless dent removal |
1991 Ford Mustang GT
I'm curious to know why 1.7 rockers if he got a custom cam
1992 Lx
11.39@119.24
if he already had them when he got the cam ground he coulda had it speced for them
89 GT
They're not too big for a 302 with the right cam, intake and exhaust. Would need valve events to have an idea of what the cam is doing and duration @.200 would be even better... and even then, it'll be tough for someone who's not an engine builder or a cam grinder to give you a good idea.
1991 Mustang LX 5.0
I'd have to find my cam card to be certain (not sure where it's at) but the lift and lsa is the same as my tf stage 2 cam. Not sure about the duration though. You sure it's custom?
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: Victor Jr Heads on this build? Specs inside...
| all the cams specs INSIDE | Sash | 99-04 | 11 | April 26th, 2012 12:23 AM |
| Victor Jr 60 cc heads? | Siegedg505 | 5.0 Mustangs | 1 | April 15th, 2011 01:24 AM |
| Vaccum readings Carbed 5.0 specs inside | ujslost | 5.0 Mustangs | 26 | January 16th, 2008 11:16 PM |
