charging help!
Old May 7th, 2007, 06:50 PM   #1
95 gt vert
pnyboi is on a distinguished road
charging help!
I upgraded to a 3g alt. because of the horrible charging problem with the foxes. my alt gauge still bounces and lights dim when at idle. is this just as easy as upgrading to a heavier power wire or maybe something else? Any ideas would be great! Thanks.
95 gt vert/88 5.8 GT
Old May 7th, 2007, 07:46 PM   #2
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
me tooo! do you have u/d pullies
Build #1249
MM New Edge Crew Member# 6
Old May 7th, 2007, 07:48 PM   #3
fogged306's Avatar
89 GT
How many amps it the alt. rated at idle? Is it an internal or externally regulated alt? Some high amp alternators actually produce less amperage at idle than the stock ones. Only at higher RPM's do they produce more than stock. Note: SOME aftermarket alternators are like that, not all.
You could also try upgrading the wires to 4ga or better. Especially the ground from the block to the chassis and the ground for the battery. It never hurts to have good wire and good connections.
Old May 7th, 2007, 07:54 PM   #4
95 gt vert
yeah, I do have pulleys, supposed to be 75 amps at idle. 130 at 2500 rpm. the article I read about the upgrade said that even with the pulleys it should have awesome charging. I guess ill try the wire upgrade and go from there. thanks
Threads Similar to: charging help!
UD Pulleys Rob Charging System? Finegan 2005 - 2010 4 April 17th, 2007 02:16 PM
Charging problem or battery shadowgames81 5.0 Mustangs 12 January 13th, 2007 03:34 PM
Charging Problem... Please Help! cstmp8r Audio/Video 3 November 13th, 2006 02:47 AM
