Is it possible to make a 5.0 even firing?
Old May 17th, 2011, 04:39 PM   #1
African_Mustang's Avatar
no car yet )=
N/A
African_Mustang is an unknown quantity at this point
Just wondering since i have a custom crankshaft grinder in my city. And if they did do it would it sound european/exotic? just wondering......
I make sick remixes and upload them to youtube for the world to enjoy.
www.youtube.com/user/Peugot905
Old May 17th, 2011, 04:47 PM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
wtf. think of the distributor
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old May 17th, 2011, 06:18 PM   #3
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Thinking outside of the box can be bad.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 17th, 2011, 06:19 PM   #4
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
It would sound like a v6! You should do it.
MAD Stangs #8
Old May 17th, 2011, 07:38 PM   #5
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Are you serious?
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old May 17th, 2011, 11:35 PM   #6
ryanw's Avatar
1991 Ford Mustang GT
Not another thread
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 18th, 2011, 12:09 AM   #7
Uber88GT's Avatar
1988 Mustang GT
Uber88GT is on a distinguished road
Do it. It will sound Czechoslovakian.
Old May 18th, 2011, 09:11 AM   #8
damn it to hell
Old May 18th, 2011, 05:28 PM   #9
no car yet )=
N/A
How could a even firing mustang 5.0 motor be bad?
Old May 18th, 2011, 07:03 PM   #10
Uber88GT's Avatar
1988 Mustang GT
Phone the shop you are talking about and ask them. Then find out how much a camshaft would cost for your custom firing order, and a custom distributor cap.
Then, after wasting all that time, realize that the Ford engineers know a hell of alot more than you and have it figured out.
Old May 18th, 2011, 07:26 PM   #11
fogged306's Avatar
89 GT
You would need an even fire crank too. The rod journals would need to be offset in order for you to be able to use an even fire firing order. Then you would have to have the even fire cam, and you would have to re-wire your injectors to fire correctly for the set-up.
Edit: nevermind on the crank.. I just did some looking up and it was the v6's that had the offset journals... Still can't change the firing order on these cars tho outside of the HO and non-HO firing order as far as I know.
Old May 18th, 2011, 10:25 PM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
eeciv fire on each bank. all four left and all four right.
Old May 18th, 2011, 10:26 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
An oval cap, or square?
Old May 19th, 2011, 08:00 AM   #14
fogged306's Avatar
89 GT
Not the HO engines. They're sequential. I believe some of the older non-HO engines were batch fire, but I know all the HO engines were sequential.
Old May 19th, 2011, 01:31 PM   #15
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
I presume you don't just mean even fire, but a flat plane crank, so that there is no odd pulse in the exhaust. You would need a fabricated crank and a matching cam as well. The electronics are the least of your worries - you can always rearrange your distributor wires and your injector wires.
It might be cheaper to fabricate a set of 180 degree headers that are tied to the firing order and cross over under the motor - that would get you the same sound with the stock firing order. And you'd be able to keep the engine balanced - a V8 with a flat plane crank cannot be balanced against second order vibration (which is the biggest reason Ford didn't do something like that).
Old May 19th, 2011, 02:05 PM   #16
Tony Silva's Avatar
1991 convertible GT
Tony Silva is on a distinguished road
Euro hi-po engine & even firing with short stroke and small pistons is good.
Ford hi-po engine & even firing with long stroke and large pistons is bad.
TWISTED CRANK WILL PROBABLY BE THE RESULT.
Old May 19th, 2011, 06:22 PM   #17
895.sloGT's Avatar
1989 Mustang GT
14.1
895.sloGT is on a distinguished road
dont forget you need a new cam too otherwise valve timing would be off
"Whether you think you can or think you can't - you are right." ~Henry Ford and I think my car will eventualy hit 10's
Old May 19th, 2011, 11:41 PM   #18
1986 GT
Bolt23 is on a distinguished road
I have seen a 302 run with a 180 degree flat plane crank and a custom cam. Problem is that no matter how you balance it it will have an inherent vibration SOMEWHERE in the rev range, I'm not sharp on it but it is possible to balance or tune it in a way that that magic number is outside its operating range.
To me it sounded like a harley on steroids but that had a lot to do with the exhaust. It made hella torque (Especially low end) but had hella problems. Its something cool but expensive and tough to pull off correctly.
Old May 19th, 2011, 11:48 PM   #19
1992 Lx
11.39@119.24
lol at custom dizzy cap.
Cant reroute the wires? lmaoooooooooooooooooooo
Old May 20th, 2011, 08:07 AM   #20
1993 5.ohhhh
12.97 @140mph
Dude, just move the wires on the dizzy around until it sounds tits.
Threads Similar to: Is it possible to make a 5.0 even firing?
Even firing 98mustangv6 V6 Mustangs 35 October 26th, 2010 05:41 PM
Firing order gnr_70 99-04 3 January 8th, 2010 07:06 PM
M-16 firing WilltheThrill The Clubhouse 9 March 4th, 2008 12:24 AM
miss firing the tick 5.0 Mustangs 5 August 22nd, 2007 10:03 PM
firing jonnotch 5.0 Mustangs 2 June 4th, 2007 05:04 PM
