Bolt Size?
Old May 18th, 2011, 10:48 PM   #1
93horseman is on a distinguished road
Bolt Size?
I ve lost the bolt that attaches my clutch cable to the frame inside the engine compartment in my 93 5.0. Does anybody know the right size?
Old May 18th, 2011, 11:32 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I think it's more of a screw type bolt. Mines not in there at the moment either. If you have a tap and die set, just drill the hole out and tap it to whatever you want.
Old May 19th, 2011, 12:02 AM   #3
ryanw's Avatar
1991 Ford Mustang GT
I think its a 1/4"
20 threads per inch
3/4" long
I thinks its the same as your oil pan bolts....thats what i have in mine
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 20th, 2011, 08:02 PM   #4
Thanks for the replies. I'll grab a bolt from the hardware store and see if works. If not the tap and die will come out.
Threads Similar to: Bolt Size?
Need bolt size. JakeM 94-95 1 May 1st, 2011 02:22 PM
Bolt size help 01 blue bullitt 99-04 2 December 19th, 2010 07:36 PM
BOLT Size!!! sixxxshoooter 5.0 Mustangs 25 November 26th, 2008 09:40 PM
Bolt size help please threetime 5.0 Mustangs 1 October 7th, 2008 10:03 AM
bolt size yankeestang 94-95 3 July 10th, 2008 03:37 AM
