95 mustang gt
1984 gt alternator problems help
my 84 gt 5.0l is charging 16volts i have replaced the voltage regulator and the alternator tested good what could cause this im lost
1992 Mustang LX
13.8
are you looking off of the voltage gauge or are you using like a multimeter on the battery. i thought i was having a charging problem and it turned out that the gauge is reading wrong.
![]() 70mm TB, 75mm MAF, BBK CAI, Edelbrock upper and lower intake, 30lb injectors, Port/Polished E7 heads, some cam, bbk short headers full flowmaster exhaust with H pipe RUNNING ON E85
95 mustang gt
i used a multimeter and it blew my ignition module and coil as well
1992 Mustang LX
13.8
it blew them by using a multimeter on the positve and negative terminals of the battery? im stumped
1991 Ford Mustang GT
what year did they start putting the volt regulators inside the alternator
95 mustang gt
no my alternator overcharging blew the module and coil not the multimeter
and the internally regulated alternator started in 85 i believe |
95 mustang gt
anyone have any ideas im lost here?????
1 Did you get the regulator from Advanced auto or Autozone? If yes its possible it is defective since they sell very cheap parts.
2 When did the problem start? Did you replace anything or add anything before this started to happen? |
95 mustang gt
i did get it from autozone but have warrantied it twice and no i didn't change or do anything it just started overcharging
Are you saying you retuned it twice? or bought 2 warranties on it? Theres really nothing else it can be. The external regulated charging system is very straight forward. I do believe you need to start following the wires from the alt, to the regulator, and thru the harness. A short may somehow be causing a bypass on the regulator. Check the plug that goes into the regulator as well.
Hey, Just my .02 I had a bad battery (cell was shorting out ) and it caused an over charge. I found it when I unhooked the battery while the car was running and the volts jumped down where they should be.
but I don't think unhooking the battery while the car is running is a good idea. But that's how I found it. Lee |
Unhookin the battery while running is ok, i have done it tons of times. A bad cell could cause a short.
95 mustang gt
ok thanks for the ideas ill try checking the battery next
Let us know what you find
Threads Similar to: 1984 gt alternator problems help
| Alternator Problems? | tater302 | 99-04 | 21 | December 24th, 2010 11:42 AM |
| Alternator Problems ( I Think) | rdspins89 | 2005 - 2010 | 8 | August 10th, 2010 08:17 AM |
| PA Performance 3G Alternator Problems | dennislv | 5.0 Mustangs | 2 | March 26th, 2010 02:08 PM |
| Alternator problems/wiring | Ford5.0 | 5.0 Mustangs | 3 | November 18th, 2009 02:09 PM |
| alternator problems | PolishSasquatch | 5.0 Mustangs | 0 | October 20th, 2009 10:42 PM |
