AOD Shifting Very Late
Old May 21st, 2011, 02:47 AM   #1
91Stang5.0's Avatar
1991 Ford Mustang GT 5.0
91Stang5.0 is on a distinguished road
I have a 91 LX AOD shifting at high rpm. It's typically shifting at around 3500 rpms and letting off the gas. It's got a new transmission that has been built up and has a "Transgo Full Race shift kit". TV Pressure has been checked by multiple ford mechanics and other mustang specialists and they say the transmission is working fine and that it's more than likely the shift kit causing the shifting. Somehow, I feel that it may not be the shift kit. It's a new transmission that was pre-built with high performance parts, so I don't think the governor or valve body is stuck in someway.
Will post a video soon of the issue for better illustration.
""If the TV cable is not connected the transmission will default to full TV pressure. If TV pressure is full shifts will only occur at the wide open throttle shift point, which is usually around 4900 RPM. This means that even at light throttle you would have to get to 4900 RPM to get a 1-2 shift." --Sounds like I have too much TV Pressure as this sounds about like my issue." - Baumann
Is there any truth to the above statement?...My cable is attached by the way.
1991 Mustang GT 306 - Built AOD w/External Cooler, 4.10s, TF Stage 1 Cam, TF Intake, Pro Comp Heads, Pacesetter LT Headers, BBK CAI, 10:1 Comp, Too much to list inside the engine......Turbo or Super Charger coming soon
Old May 22nd, 2011, 09:51 PM   #2
91Stang5.0's Avatar
Bump
Old May 23rd, 2011, 11:11 AM   #3
95StangMX's Avatar
95 Mustang GT
Its most likely the shift kit, what does it do when you manual shift it?
Threads Similar to: AOD Shifting Very Late
Its Late Im Up Chris'schick The Clubhouse 31 July 6th, 2008 02:32 AM
too late G.T. Rags The Clubhouse 48 July 3rd, 2008 05:26 AM
Late Shifting ( Part 2 ) Ram5773 99-04 6 October 11th, 2006 09:07 PM
Late Shifting Ram5773 99-04 20 September 20th, 2006 10:14 PM
automatic tranny shifting too late? 2007gt 4V / SVT 1 August 24th, 2006 03:46 AM
