Look Ma! My First Post!
87 performance help
hello guys im new here.. was wondering what i should do to my mustang to add to my mustang for more power. its an automatic with a shift kit tranny already i dont know what brand though. eveything on the engine is stock.
thanks |
2006 GT
11.99@114
Welcome. What is your budget? Do you know what gears you have?
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
87 GT Vert
If you plan on doing anything to the engine you should go ahead and convert to mass air first.
I love all my fans. |
1987 GT
13.19 @ 107.02 (street tires)
Welcome to the forum!!
There are some things you can do for free to add a few ponies. I don't know your experience level, so I'll start here. Anyhow, there was an old issue of muscle mustangs and fast fords that listed these in the 1990's - maybe you can find it online somewhere if you googled it, or maybe it's on this forum somewhere too. From what i can remember: Make sure the air silencer is removed from the fenderwell, bump the timing to 13-14 degrees if you have access to a timing light and run 93 octane fuel, adjust the throttle position sensor voltage to 0.98 volts at zero throttle and engine key on not running. Make sure your plugs are gapped correctly. Make sure your air filter is clean. Take off you air intake tube and make sure your throttle blade is opening the whole way when the pedal is floored, etc. If you are looking for the most "seat of the pants" feel, I would start with gears, 3.73 or 4:10's depending on whether you want; just performance 4:10 or a mix of that and highway driving 3:73. It would be a very good idea to put subframe connectors on it so you don't twist it up. Most people say that's the first mod you should do to any fox body. Anything to the motor (heads, cam, blower,etc) and you will probably need to convert to mass air. You could go the heads/cam/intake route if you want to go all motor. You could go nitrous (probably the cheapest up front). I went supercharger just because I've always wanted one. So many options. Just let us know your budget and your goals. There are many guys on here that know loads more than I do, so just ask. |
#5 | |
1991 Mustang LX 5.0
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: 87 performance help
| HP Performance | slikirish | 99-04 | 7 | October 5th, 2010 07:09 PM |
| i should of gone with performance but | mustang1072 | V6 Mustangs | 52 | April 24th, 2007 12:59 AM |
| staight line performance or track performance??? | andoutcomethewolves | V6 Mustangs | 12 | February 19th, 2007 11:34 AM |
| B&G or HP Performance????? | iraqiterminator06 | General Tech | 3 | February 10th, 2007 05:52 AM |
