To Tune or not to Tune? That is the Question! - Page 2
Old May 10th, 2007, 12:51 AM   #21
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
$100 for 3 pulls is too expensive??? Please.
Dyno time is always worth the money. Alot can be done in 3 pulls.
Old May 10th, 2007, 05:19 AM   #22
Mr_Evil's Avatar
Mr_Evil is on a distinguished road
Yeah, $100 for 3 pulls is a little steep. 1st run to see where it is at, 2nd run to see what your adjustments did, 3rd to pray it is close, because you dont want to fork out any more money. And Dyno time is only really worth the money if you are makin' money with your car.
Dyno's are kind of the exclusive & secretive tool only available to a few with some cash. Because you can spend hours on a Dyno easily trying to get a decent tune. Not many have them, & not many advertise they have them. So I have no sympathy saying that they charge a lot. Appears they really dont want to sell their product.
Old May 10th, 2007, 06:21 PM   #23
Kevin b is on a distinguished road
So is this the one I would wan
*BRAND NEW*
APEXI AFC NEO
Description
YOU ARE BIDDING ON A BRAND NEW APEXi AFC NEO
FREE UPS GROUND SHIPPING WITHIN 48 USA STATES!
Part number: 401-A917
MSRP: $469
- Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
t to buy?
Old May 10th, 2007, 06:51 PM   #24
Also Does anyone know where to get the wiring diagram to hook this up to the mustang computer? I have been all over and can not find a specific site on how to do it. Let me know if some one has hooked one up in a mustang. It shows they are for imports.
Thanks Kevin
Old May 10th, 2007, 08:22 PM   #25
Mr_Evil's Avatar
You will wire it in the same way as you do on the other cars. Just the wire colors will be different. I had an older one. I thought I saw the mustang on the list of cars back then. But I cant find that info now. But like I said, the wire colors is the only thing different... And, Yeah', that Neo is the one to get. It is the newest one. You could get a SAFC-II. It should work also. May be a little cheaper due to it being the previous version. You may want to check to see if your Mass Air Flow Sensor works on the 0-5v scale. I think it does. May just want to double check.
Threads Similar to: To Tune or not to Tune? That is the Question!
dyno tune & flash tune miafan 2005 - 2010 4 May 31st, 2007 05:05 AM
tune question! nhvickery 2005 - 2010 8 March 25th, 2007 12:58 PM
Tune up question 1996gt 96-98 7 February 6th, 2007 05:14 PM
Another tune question GTNorm 2005 - 2010 0 December 30th, 2006 09:13 AM
Tune Question GTNorm 2005 - 2010 14 October 27th, 2006 11:59 PM
