Need help/answer ASAP ?
I have a 87 fox body and I'm doing a 351 swap with hedman headers and I wanted to know would a bbk h pipe fit or would I have to go with another company ?
Ice Cream Truck Driver
if you have shortie headers, then you want a full size H pipe. brand shouldnt matter as long as they are made for your car. if your doing long tubes you want a long tube h pipe. thats all. it should fit no problem
![]() MM+Cleavage Club Founder/Member #1 *MM's Thread of the YEAR*
Ok cool thanks cause I do have long tubes with off road h pipe
1989 Black LX---Turbo
To my knowledge Hedman doesn't make a 351w swap header. You must run 351w specific headers or modify your mid exhaust system. I would think 302 long tubes on a 351w would hit the floor boards because of the deck height difference!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
Proud American
With the difference in deck hieights comes a slight difference in the width of the two headers where the collectors are...
this is what I ordered... and I had to weld it all together to make it work. Dr. Gas Exhaust - Store - Mustang X-Over System for Mac Long Tube Headers
So as long as the headers fit then the h pipe shouldn't be a problem connecting to everything is that correct ?
Couldnt you use lowering mounts to solve the floor board problem?
not entirely. my buddie did a 351w swap and had to use swap headers after trying his old 302 shorties. even with 1in drop mount (or 3/4in?). but if your running long tubers...im just gunna shut up because i dont know shit about em. but every time i see of the shelf long tubes, i notice they hang way lower than the body so you may need to mock up your engine and exhaust to see where you stand. (this will answer any question you have about your exhaust if no one gives you a direct answer
Threads Similar to: Need help/answer ASAP ?
| Need A Hood Question Answer Asap | NorCalWhtHrse | Visual | 15 | August 14th, 2009 11:29 PM |
| Quick Question About Wheels!!! Need Answer Asap!! | RedDevilGT | V6 Mustangs | 3 | August 13th, 2009 10:45 PM |
| Please Answer Asap! Seats Help | svtkidd23 | General Tech | 24 | February 9th, 2009 11:28 PM |
| Answer needed asap for interior | hopper | 5.0 Mustangs | 3 | July 18th, 2008 09:38 PM |
| (Answer ASAP!) Tension Pully | greyauto02 | V6 Mustangs | 1 | December 25th, 2007 05:54 PM |
