1992 Mustang breaking up in mid-range
Old May 23rd, 2011, 07:10 PM   #1
1992 Mustang LX
6.0GA-Stroker is on a distinguished road
I have a 1992 mustang lx with a 351W fuel injected. And it's breaking up in the mid range, and horrible aceleration. It idle's great. I just did plugs and wire's, the cap and rotor look good. idk if it's starving for fuel or a timing issue?
Old May 23rd, 2011, 10:23 PM   #2
fogged306's Avatar
89 GT
Whats your mods? Did this just happen out of nowhere or has it always done this since you've had it? Who did the 351 swap?
Old May 23rd, 2011, 11:25 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
I'm going to give you the thumbs up on keeping it fuel injected, now we need to talk some of these other kids that want to do the same swap to keep there's EFI instead of going carb
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 23rd, 2011, 11:36 PM   #4
nxcoupe is on a distinguished road
Need more info on your combo and as previously posted, what was the last thing you did before you started noticing this issue? I'm going through a similar issue, so I need to know more info to see if it's the same problem I'm having.
90 GT 393 5 spd, 467 rwhp 480 rwtq
92 coupe, R/S 308 5 spd
93 coupe, 2.3 5 spd
Threads Similar to: 1992 Mustang breaking up in mid-range
1992 Mustang LX 2.3L N/a (What to do?) TheMike7533 2.3 Mustangs 17 October 5th, 2010 12:08 PM
1992 mustang gt 01dutchGT Classic Mustangs 4 December 24th, 2009 08:15 AM
My 1992 Mustang needs help ugk1 2.3 Mustangs 11 March 18th, 2007 10:49 PM
1992 mustang GT firefly1241 5.0 Mustangs 8 December 3rd, 2006 11:46 PM
