5 lug Conversion
Old May 23rd, 2011, 07:25 PM   #1
foxvert91 is on a distinguished road
5 lug Conversion
Ok I have a question either nobody will have the answer to or one everyone knows. I bought a thunderbird super coupe differential from a guy a few months ago. They come with 3.55 and 3.73 gears with disc brakes so I thought it was sweet for only 200 bucks. However, now I want to go for a 5 lug conversion. I think the guy said they are 31 spline. So I know latemodelrestoration.com sells complete kits for cheap. But will they work since I have this differential? It is still an 8.8 but I wanted to make sure. Thanks
Old May 24th, 2011, 12:14 AM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
well the supercoupe has independant rear suspension. i dont think that will work with fox mustangs parts
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old May 24th, 2011, 01:48 AM   #3
Ice Cream Truck Driver
Spike Digidy!'s Avatar
85 CARB GT / 91 FI LX
Spike Digidy! is just really niceSpike Digidy! is just really niceSpike Digidy! is just really niceSpike Digidy! is just really nice
Send a message via AIM to Spike Digidy! Send a message via Yahoo to Spike Digidy!
your best bet if you want a easy 5 lug conversion if to buy a sn95 differential and front wheel spindles from a junk yard. its a cheap direct bolt on. you could sell the t-bird rear end and buy everything and still have cash left over
MM+Cleavage Club Founder/Member #1
*MM's Thread of the YEAR*
there was this black kid in 8th grade and i said "sup black boy?"
Old May 24th, 2011, 01:48 PM   #4
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Is it just the 94 and 95 that are direct bolt on?
Old May 24th, 2011, 03:39 PM   #5
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
some people do that others take axles from aero stars broncos and rangers. the thing is useing those parts is you have to take the drivers side only because the diff isn't in the middle
Old May 24th, 2011, 04:11 PM   #6
im not too shure on the exact years, but as long as its a sn95 body with spindles and hub rotors, its a direct bolt on (as so is the rear diff). and you'll also have rear disc brakes. its also recomended to replace the master cylinder, but you can get away without doing so. you brake pedal will just be a bit tougher. and from then on, just buy 95' brake components when serviving your brakes.
Old May 24th, 2011, 04:13 PM   #7
jjpluml's Avatar
1987 5.0 HO, 1984 SVO
jjpluml is on a distinguished road
where are you located?
92' lx 2.3 bone stock dd trunk car
84 SVO with a few bolt ons
87 gt project with a whole bunch of shit thrown at it and a lil juice...
Old May 24th, 2011, 04:17 PM   #8
America
Old May 24th, 2011, 04:26 PM   #9
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
the spindles are 94/95 only because of the tie rod mounting location i think you can use 96+ but it will cause steering issues and you need to either use ball joints from a 94/95 or use some washers on top of the spindle if you use the fox ball joint
Old May 24th, 2011, 04:45 PM   #10
force-fed-snake's Avatar
93 GT
force-fed-snake is on a distinguished road
fox and sn95 housings are the same, sn95 axles are longer from the housing "out" about .75" per side. all the of the sn95 5 lug axles/rear disk is a direct bolt on... with minor work adapting brake lines/ ebrake cables
fox ball joints plus sn95 spindles = washer/spacer under the nut... no matter the year.
do a search for 5 lug swap.... if you are on a budget... you can simply switch to 5 lug front rotors, without swapping to sn95 spindles/unit bearing hubs. the sn95 upgrade is geared more towards wanting to run 13" cobra barkes in the future.
Old May 24th, 2011, 08:07 PM   #11
but then I would have to worry about getting a posi unit wouldn't I? or did they come posi with good gears? I need 3.73's
Old May 25th, 2011, 03:24 PM   #12
93 GT
as far as SN95 housing is concerned.... gt will be limited slip.
the gears will suck, so you will need to buy the R&P of choice.
while you "could" run a set of used gears... why? they are cheap, as is the install kit.
the expense will come from having it proper set up. a lil hint here.... you will prob get a better install deal if you take the housing in for a "bench install"
Threads Similar to: 5 lug Conversion
GT conversion T-Money 2005 - 2010 15 August 26th, 2010 09:40 AM
LED Conversion longhorn70 94-95 2 March 29th, 2010 10:51 PM
Conversion Blackblurr_00GT 99-04 1 January 11th, 2008 06:16 AM
Five Lug Conversion! Olita 1 5.0 Mustangs 23 December 26th, 2007 10:35 AM
conversion patwrecked 5.0 Mustangs 0 May 8th, 2007 01:46 AM
