331 issues
Old May 24th, 2011, 08:31 PM   #1
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
331 issues
Hey guys im working on a 1995 5.0. It has 30lb injectors with matching MAF. I have gotten almost all the bugs worked out of it except a few. When driving normaly and coming to a stock light you press the clutch in and the RPM's hang up around 2k for about 5-10 seconds and then drops to idle. The other problem is in second gear it feels like it misses about 2000-2500. Sometimes its higher in the RPM range than that also. I thought it might have been running out of fuel so i put a adjustable fuel pressure regulator and gauge and set the pressure to 45psi without vacuum line hooked up. I know that is kind of high but i wanted to start high. It still misses the way it did with the stock regulator.
Things i can think could be the issue with the missing problem.
1. Fuel pump (it is stock)
2. Tune (it has stock tune, but i figured it would at least run alright)
As for the idle i may just try and get a new TPS. If i do get a new TPS do i need to set the voltage with the procedure in the sticky?
Thanks for the help guys
1988 vert - still in progress
2004 F250
Old May 24th, 2011, 08:41 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
you have a 331 stroker ? and a stock fuel pump ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 24th, 2011, 08:44 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Make sure your starting point is lower than 1 volt and like over 4.5 at full throttle. Fogged306 knows his electronic shit pretty well, and he said the .95-.98 is just a myth. I still do it anyway, but that's cuz it's easy and although it may not help, it certainly doesn't hurt. Without checking the full sweep of the TPS with a meter, you may just be pissing money away. The one on there might be good. Probe the wires and slowly open the throttle and watch the voltage. If it's a steady sweep, you are good. If it's erratic, junk.
Old May 24th, 2011, 08:47 PM   #4
1988 Mustang
Ryan, its not my car. I didn't build the car. I am just trying to get all the buggs worked out, there has been quite the list. I will be getting a walbro 255lph. Faststang, i will check that the voltage is right like you said and then i will do the resistance sweep also to make sure its steady. what else do you think the hanging RPM thing could be?
2004 F250
Old May 24th, 2011, 09:02 PM   #5
1991 Mustang LX 5.0
I know someone on here had it happening, but I can't remember what the outcome was. I have the memory of an 80 year old with alzheimers.
Old May 24th, 2011, 10:42 PM   #6
fogged306's Avatar
89 GT
Have you checked for codes? Read the plugs? I agree, I would definitely get a bigger pump in there before anything, it might not be your miss, but it needs to be done regardless.
Hey Scott, this is actually a really good read about the TPS voltage. stang&2birds in that thread makes a lot of sense out of it. EECTuning.org • View topic - Why TP voltage does not matter
Old May 24th, 2011, 11:08 PM   #7
1991 Mustang LX 5.0
I didn't make it that far.... that shit's WAY above my head. I'm a dyno tuning kind of guy, lololololololololol.
Old May 24th, 2011, 11:13 PM   #8
fogged306's Avatar
89 GT
Hah, don't pay attention to the screenshot in the first post. Thats beyond me at the moment too. But the RATCH functions explained pretty plainly makes a lot of sense. Trust me, it's not as technical is it looks.
Old May 24th, 2011, 11:20 PM   #9
1991 Mustang LX 5.0
Hell, I haven't even looked at modifying the outputs for the Abaco meter yet either, I just ran it as was. But didn't have a wideband either, so really would have been pointless... nothing to compare it to. I'll finish reading that later - promise
Old May 25th, 2011, 01:30 PM   #10
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Have you checked for vacuum leaks?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old May 26th, 2011, 06:03 PM   #11
1988 Mustang
There are no vacuum leaks. I reset the base idle and i am putting a 255 walbro in it and i hope that fixes the problem. i see the fuel pressure needs to be set to 35-45psi. Got that off alldata. What do you guys suggest fuel pressure be set at?
2004 F250
Old May 26th, 2011, 06:28 PM   #12
kmedeiros88's Avatar
89 Mustang LX Hatch
kmedeiros88 is on a distinguished road
39 psi
Old May 26th, 2011, 08:02 PM   #13
fogged306's Avatar
89 GT
Originally Posted by kmedeiros88 View Post
39 psi
with the vacuum line off the regulator. 39 PSI is the target for the EEC at WOT. When you go WOT, there's no vacuum in the manifold so the FPR is at it's max PSI, which is why you pull the vac line off and set it. If you're within a couple PSI you're fine.
Old May 26th, 2011, 08:35 PM   #14
1988 Mustang
Ok thanks, yeah i know how to set it. I was just wondering what you guys thought. If i still get this miss im going to try and bump it up a little and see if the miss feeling goes away. 30lb injectors should be enough to fuel this build i think. thanks for the input guys
2004 F250
Threads Similar to: 331 issues
Fan issues... help =( sharkbait 96-98 6 December 24th, 2009 03:58 PM
issues with 97 gt racer1997 96-98 13 June 10th, 2009 03:44 AM
t-5 issues cburns 5.0 Mustangs 6 October 24th, 2008 01:44 PM
HELP...New SCT-issues DEUCE 99-04 2 April 29th, 2008 02:48 PM
Issues... mustang1072 V6 Mustangs 20 December 18th, 2007 01:09 PM
