Car sputters an feels like it wants to die - Page 2
Old May 24th, 2011, 11:53 PM   #21
BlueberryStang's Avatar
1990 Mustang GT
BlueberryStang is on a distinguished road
I saw on another thread that crossed plug wires could have somewhat of that effect is that true? I don't see how it could, but I don't know.
1990 GT hatchback - BBK cold air intake, shorty stainless headers, FRPP 4.10 gears, MSD ignition, underdrive pulleys, 2.5 inch exhaust with o/r h-pipe into Flowmaster super 10series.
Old May 24th, 2011, 11:55 PM   #22
1990 Mustang GT
Originally Posted by ryanw View Post
It takes less then 10 min to run your codes...get off the computer and go do it....report back what you find
I don't have anything to run em with?
Old May 25th, 2011, 12:00 AM   #23
ryanw's Avatar
1991 Ford Mustang GT
If you read the links that faststang posted it tells you how to do it. YOU USE A JUMPER WIRE ON THE DIAGNOSIC TERMINALS UNDER THE HOOD ON THE DRIVERS SIDE...It make s your check engine light on the dash board flash, you then count the flashes and then check the number to the corresponding codes
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 25th, 2011, 12:02 AM   #24
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Find a paperclip
Old May 25th, 2011, 12:09 AM   #25
1990 Mustang GT
Well I can't do it right now it's 11pm an too dark.
Old May 25th, 2011, 07:44 PM   #26
kmedeiros88's Avatar
89 Mustang LX Hatch
kmedeiros88 is on a distinguished road
Sometimes the dash light won't work. I know on mine it doesn't. I have a dash light but it doesnt work, I used a jumper and a test light from autozone. This should be the first thing you should do. I still think its your TPS.
Old May 28th, 2011, 05:30 PM   #27
88BlackPonyGT is on a distinguished road
clogged cats?
Old May 29th, 2011, 04:17 PM   #28
GTNBY2's Avatar
1991 GT
Never ran it
GTNBY2 is on a distinguished road
How long have the wires been on and did it start after the header swap? Sounds too simple but have you checked your wires for arcing? you can do that real easy at night!!! LOL I emplore the K.I.S.S. method (keep it simple stupid). Also look the cap over for cracks or hair line fractures... if your firing more than 1 cylinder at once it can easliy do what your describing....
GTNBY2
Threads Similar to: Car sputters an feels like it wants to die
Car sputters...I'm STUMPED! ihateyou 5.0 Mustangs 7 March 27th, 2010 06:12 AM
Sputters in reverse wveil3v 2005 - 2010 1 January 21st, 2010 04:07 PM
Please help! Car sputters and lurches... dcook_14 99-04 16 September 8th, 2009 04:09 PM
car sputters under throttle lilmarc1988 99-04 13 June 7th, 2009 10:42 AM
Car sputters when hot. dr.gonzo! 5.0 Mustangs 5 August 17th, 2007 02:57 PM
