Whats thats called?
Old May 24th, 2011, 11:28 PM   #1
1990 Ford Mustang GT
jwallace410 is on a distinguished road
Whats thats called?
There was a small diameter metal pipe that was running from the passenger side of the engine compartment down to I think the Exhaust or Catalytic conveters... I dont exactly know what it was 'cause the guy who offered to do my header job cut it out with a grinder and left after saying he couldnt finish the job... So i went and bought shorties and installed them, but am still left with this pipe.. It looks like theres a spot for a vaccum line to attach, like a blow off valve, but I know... Its not one. If you know what this is, could you help me? And If so, i doubt that ill be able to replace it so how would I be able to delete it... I believe that smog pump kit is involved, but plugging holes seems to be the issue.. Sorry, just started working on cars myself, and teaching myself as i go. Thanks for all the help!
Nw Baghdad Iraq 07-09
Kandahar, Afghanistan 2010 17 Days PH awarded.
Strike BCT, 101 ABN "SAPPER BEAST"
Old May 24th, 2011, 11:30 PM   #2
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
EGR maybe ......... I doubt your car has 1 tho
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old May 24th, 2011, 11:32 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
It's just for emissions and and feeding air to your cats. Has nothing to do with the headers. Where on the tube did he cut it? Up top, or down at the bottom?
Old May 24th, 2011, 11:33 PM   #4
1991 Mustang LX 5.0
Which is why ^^^ should stay in his own section
Old May 24th, 2011, 11:33 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
that feeds air to you cats, from your smog pump
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 24th, 2011, 11:37 PM   #6
1999 mustang cobra
Crew Member # 5
Old May 25th, 2011, 12:47 AM   #7
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Do you have to get an inspection sticker in your state?
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old May 26th, 2011, 08:42 PM   #8
No inspection sticker, and I didnt know what the pipe is, and this is a 5.0, figureed a general question would belong here. Thanks for the info fellas, i believe if i add the smog eliminator kit, the instructions say to plug the tube with 5/8 rubber caps so i think ill be ok, thanks again.
Threads Similar to: Whats thats called?
Whats this part called? jeff 99-04 12 September 30th, 2010 10:11 PM
whats its called? crappy_head The Clubhouse 32 November 1st, 2008 09:08 PM
whats the place called gooberhead320 The Clubhouse 10 May 6th, 2008 01:36 PM
Whats it called? scxc15 V6 Mustangs 10 January 25th, 2008 08:07 AM
Whats that thing called scxc15 V6 Mustangs 26 May 4th, 2007 12:07 AM
