1988 Ford Mustang GT Convertible Mustang Problems
Old May 8th, 2007, 10:09 PM   #1
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
My uncle gave me a white 88 Gt vert for free, and it runs perfect but has some things that need to be worked on.. For one the horn doesnt work at all.. I was driving it today and out of nowhere theres a squeaky sound from the car that u really cant hear it unless u pay close attention to it.. could it be the shocks, suspension? Thanks
Old May 8th, 2007, 10:42 PM   #2
ujslost's Avatar
probably the suspension or throw out bearing if its a 5 speed
Old May 9th, 2007, 01:35 AM   #3
neverfastenough's Avatar
neverfastenough is on a distinguished road
Could be a belt or worn brakes too. I never heard a squeaky throw out bearing, but I never owned a T-5. I have heard throw out bearings go grrrrrrrrrrrrrrrrrrrrrrrr. You know that grinding sound. I couldn't figure out how to spell it.
Old May 9th, 2007, 04:31 AM   #4
Rustbelt's Avatar
Rustbelt is on a distinguished road
my horn or cruse doesnt work as well!
Old May 9th, 2007, 08:41 AM   #5
The cruise and horn contacts in the wheel share the same ground. Sounds like you could have a ground problem. Check both fuses. Run a wire from the battery to the horn or horns to see if they work. But the common denominator is the wheel contacts and the ground for the wheel.
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time.
Old May 9th, 2007, 09:26 AM   #6
ujslost's Avatar
start checking for blown fuses
Old May 9th, 2007, 09:41 AM   #7
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
my dad's truck has a bad throw bearing and it sounds like a bird chirping under the car. it's kind of weird.
Old May 9th, 2007, 11:24 AM   #8
Hmmm, have to keep that in mind if mine ever starts sounding like tweetie. Thanks man.
Old May 9th, 2007, 01:28 PM   #9
I Post Entirely Gay Too Much
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
there are so many ways for these cars to sqeak. on my car where the top hooks to the clamp was bent so the hooks didnt hold it down tight and it took me for ever to find out that was where the sound was coming from.
You could try some subframe connectors and that would take out the flex that these cars are known for. also lubercate all the hinges that move the top.
Old May 9th, 2007, 07:37 PM   #10
ujslost's Avatar
if the noise quits when you press the clutch in it IS the throw out bearing plain and simple
Old May 9th, 2007, 11:40 PM   #11
ridebmxfbm's Avatar
Deff.. not the throw out bearing guys... im just confused now as to what it is...? The horn also havent tried the cruise yet but will tommorow but there isnt even a horn button like cushion there to press the horn... Thanks again will 225/55/16 fit good with my pony wheels, will they rub or anything? Thanks
Old May 10th, 2007, 06:08 PM   #12
Rustbelt's Avatar
i doubt they would rub on anything unless something came loose in the wheel well.
all the regular fuses are good i need to hunt down the fuse links to check those. it looks like i have to tear into the steering col. to check the llinks there. thanks.
and this is odd i cant find the horn? where is the stock location? i think the prev owner removed it.
Old May 10th, 2007, 10:14 PM   #13
ridebmxfbm's Avatar
yup i cant find the horn either?? any info on that? Thanks
Old May 10th, 2007, 11:39 PM   #14
JBIGBOOTSY's Avatar
1990 LX hatch
sticky speedo cable? is the needle jumpy? they squeek somtimes
Old May 12th, 2007, 02:34 PM   #15
ridebmxfbm's Avatar
sometimes it is kinda jumpy, and now at times not always wen i start it has a buzzing kind of noise maybe coming from the back ? I also sometimes get really rough idle it bounces slowly from 700 to 1500 and 1000 and over and over again...
Old May 13th, 2007, 03:24 AM   #16
Rustbelt's Avatar
you need to clean the salt and pepper shakers. white and black 10 pin connecters. i think there was an article on it in here somewhere. if i find it i'll post the link.
Old May 13th, 2007, 03:31 AM   #17
Rustbelt's Avatar
http://www.fordmuscle.com/archives/2...in/index.shtml
randomly found this one. i still think there is a better one in this site somewhere.
Old May 13th, 2007, 10:55 PM   #18
ridebmxfbm's Avatar
Thanks for that, I will try it tommorow, now I'm having a headlight problem they dont go on when i switch them on I have to play around a little with the directional light stick and push it back as if to stay in high beams and it will go on sometimes and will flicker at times or shut off with my fog lights being off... I still can't figure out how to fix the horn either, it just won't work Thanks...
Old May 14th, 2007, 02:35 PM   #19
jpalm is on a distinguished road
electrical problems
Have had a few over the years on a convert and and LX, found that the ignition switch was bad on the LX (no turn signals, no a/c), when I took the connector off of it, it fell off the column. On the 91 convert, had a multitude of electrial problems and found the multi-fuction switch to be bad (turn signals, wipers, headlight bright/dim, etc....) Hope this helps.
Threads Similar to: 1988 Ford Mustang GT Convertible Mustang Problems
1988 Mustang GT Convertible Heater Core ridebmxfbm 5.0 Mustangs 5 February 16th, 2007 04:27 PM
1988 Ford Mustang, Wats It Worth? wannab5.0 5.0 Mustangs 4 October 30th, 2006 03:07 PM
